Most of the time I have a germanium or Schottky between GPIO16 and RST, sometimes a 330 ohm resistor, every now and then a 2 inch wire. All worked, depending on whether I wanted an external RESET switch.
I've never used a delay() after Deep Sleep. It shouldn't need it, as it's a different mechanism / Sleep mode than the others that DO absolutely need at least delay(1) before activating.
You don't need to do Serial.flush() before Deep Sleep. Trust me, it'll cut off in mid-byte during a printf.
The maximum theoretical deep sleep is ~ 71.58 minutes, and due to the calculation for time it's something less than that. The longest I think I got was 68 minutes and change, not 3.5 hours. How do you get 3.5 hours from 2^32 microseconds? Are you travelling near the speed of light or near the event horizon of a black hole?
I'd really like to see zombie mode, but alas my code and hardware have always worked. It's almost not worth keeping the shotgun next to my work bench.
