Have questions about FETS, transistors, measurement, power supplies, or anything else electrical?
By XingxoYamchu
#96228 I'm new to connecting an Arduino Uno and an ESP, and I have a level shifter to connect them due to the voltage difference. I want to send the values from the Uno to a webpage via the ESP. Can I connect the port B1-4 and A1-4 to the digital ports on the boards, and use the software serial library to see the serial monitor?
By rooppoorali
#96251 Are you using ESP-01 or NodeMCU? If you're using ESP-01, you can see here:
https://www.theengineeringprojects.com/ ... sp-01.html
https://www.electronicwings.com/arduino ... rduino-uno
In case you're using NodeMCU, this one will help:
https://www.youtube.com/watch?v=SiU-QZwik8w
