first of all, Happy New Year !
So...I've built a solar powered weather station equipped with various sensors, a TP4056, a MAX17043, a 18650 2900 mAh battery and an ESP8266.
I found several wiring scheme for systems with TP4056 and MAX17043 then I wonder which is the correct one.
Everything seems to work correctly, I can read voltage and SOC of the 18650 battery that is connected.
I attached the wiring scheme that I have adopted: is it correct?
Is there a better way to connect those boards?
Thank you, regards.
Roberto
