By olebowle
#14134 I had the same issue while driving the gate of a mosfet using GPIO2. Usually it is recommended to pull-down the gate, so that the mosfet is in a defined state if the uC is reset. With a 10k resistor the ESP-01 wouldn't start up properly. However, using a 100k resistor worked just fine.
By andyjwang
#19485 Can uber4 provide the diagram of how you connected gpio 2 to led please? :?:
pzwolinski wrote:
I'm having the same problem...
I have an LED connected to between GPIO2 and GND. When my ESP01 is restarted, it will not boot normally, which is a bummer. If I temporarily disconnect the LED circuit, the board will boot normally, and after reconnecting, my program works as desired (able to toggle the LED over wifi).
Is there anything I can do to get this unit booting normally without having to leave GPIO2 floating?
I had the same problem and I fixed with a 2,2k pull up resistor (4,7k or higher was not working).
Doing this GPIO2 will be high by default while it resets (1-2 seconds),
but you allways can write to low.
