By xtal
#49771 my experience with these modules ....
1> You only get about 2/3 of signal level[compared to generic -12E] , removing switch under antenna will give a little more.
2> The usb/rs232 seems to function well, I used 1 to support a 1-wire sniffer.
3> All 10 units I have seem to function properly, except for poor signal level.
By spy king
#51480 I just tried flashing my WiFi Witty using the simple Arudino blink scrip using the NodeMCU v1 board profile.
However, I see that there is always an open unsecured "ESP_81xx" WiFi connection when the board is on.
Is that part of the original Gizwits firmware? Shouldn't the new arduino firmware remove all previous firmware?
By kroome88
#58738 playing around with this witty board, yes, also experienced what you encountered on rgb led... take note that it is an ordinary rgb, not a WSxxxx series :) ... can be played around since it is connected individually...
By MosheB
