Page 1 of 4
g3mb-202p SSR with DC load
PostPosted: Thu Mar 17, 2016 10:05 pm
by markusonfire
Hi,
I've etched a PCB for a project that involves using a g3mb-202p Solid Relay driven by a NodeMCU 1.0 running Arduino Code.
The g3mb-202p was intended to provide 12vDC to an Electronic Door Strike.
Upon initial testing, with a multimeter connected to the 12vDC out (from the relay) it seemed to work fine:
~0v when the ESP set the Relay to open
+12vDC when the ESP set the relay to closed
When connected to the load (The 12v door-strike) the strike does not activate and the output of the relay shows ~0v
I've read that the g3mb-202p is only intended for switching AC loads. Howcome I see the desired results with a multimeter and not when using the actual load?
Give that I've already Etched the PCBs, is there any way I can get this relay working with my 12vDC load?
Alternatively, is there any other DC-compatible relay that has the same footprint/pinout?
Hopefully someone can help me out or provide some clarification.
Thanks in advance!
Simplified schematic (Removed MFRC522, LEDs, Buzzers, etc to get message across simply) below:
(Corrected error in image that Pablo2048 pointed out)
Re: g3mb-202p SSR with DC load
PostPosted: Thu Mar 17, 2016 11:01 pm
by lethe
The SSR you have chosen has a triac output with built-in zero-cross circiut. This means it cannot be used to switch DC loads.
I suggest you either replace the SSR with a simple transistor and optionally an additional optocoupler if you really need to isolate the load. My preference would be a mosfet (p-FET if you want high-side switching) for the transistor, but a BJT darlington transistor would do as well.
Alternatively you could use a SSR capable of switching DC loads (with a mosfet output stage), but that will probably cost more than a simple transistor and optocoupler.
Also be aware, that the button on GPIO0 will cause the ESP to enter firmware flash mode when pressed during power-up.
PostPosted: Fri Mar 18, 2016 1:07 am
by markusonfire
lethe wrote:The SSR you have chosen has a triac output with built-in zero-cross circiut. This means it cannot be used to switch DC loads.
Thanks for that feedback Lethe!
Could you help me understand the following:
lethe wrote: ...I suggest you either replace the SSR with a simple transistor and optionally an additional optocoupler..
So a transistor can be used instead of a relay?
Would the transistor and optocoupler be in addition to the existing 2n2222 transistor?
Could you suggest what spec transistor/optocoupler to use and how they would be wiring (Perhaps edit my schematic?)
In the mean time, I'l read-up on the above recommendations you've made to gain a better understanding.
lethe wrote: ...Also be aware, that the button on GPIO0 will cause the ESP to enter firmware flash mode when pressed during power-up....
Thanks, I'm aware that this could be the case, but unfortunately all "non-special" GPIO pins are in use by other components (RFID reader, RGB leds, Piezo buzzers)
Thanks again!
PostPosted: Fri Mar 18, 2016 1:17 am
by Pablo2048
To Markusonfire - check Your schematic please (emitter of NPN transistor connected to 3V3 instead of GND and so on...)
