Load program monDHT22.lua and dht22.lua to ESP8266 with LuaLoader
And the same for DHT11 sensor ... monDHT11.lua and dht11.lua
-- Demo http server for sensor DHT22 - tested with NodeMCU 0.9.5 build 20150107
-- 1. Flash NodeMCU 0.9.5 build 20150107 or later to ESP module.
-- 2. Load program monDHT22.lua and dht22.lua to ESP8266 with LuaLoader
-- 3. You can rename the program monDHT22.lua to init.lua
-- 3. HW reset module
-- 4. Login module to your AP - wifi.setmode(wifi.STATION),wifi.sta.config("yourSSID","yourPASSWORD")
-- 5. Run program monDHT22.lua - dofile(monDHT22.lua)
-- 6. Test IP address - wifi.sta.getip()
-- 7. Test it with your browser and true IP address of module.
-- 8. The sensor is repeatedly read every minute.
-- 9. The pictures on page are external.
--10. The length of html code is limited to 1460 characters.
--11. The author of the program module dht22.lua for reading DHT sensor is Javier Yanez
--wifi.setmode(wifi.STATION)
--wifi.sta.config("yourSSID","yourPASSWORD")
tmr.delay(1000000)
humi="XX"
temp="XX"
fare="XX"
bimb=1
PIN = 4 -- data pin, GPIO2
--load DHT22 module and read sensor
function ReadDHT22()
dht22 = require("dht22")
dht22.read(PIN)
t = dht22.getTemperature()
h = dht22.getHumidity()
humi=(h/10).."."..(h%10)
temp=(t/10).."."..(t%10)
fare=(9*t/50+32).."."..(9*t/5%10)
print("Humidity: "..humi.."%")
print("Temperature: "..temp.." deg C")
print("Temperature: "..fare.." deg F")
-- release module
dht22 = nil
package.loaded["dht22"]=nil
ReadDHT22()
tmr.alarm(1,60000, 1, function() ReadDHT22() bimb=bimb+1 if bimb==5 then bimb=0 wifi.sta.connect() print("Reconnect")end end)
srv=net.createServer(net.TCP) srv:listen(80,function(conn)
--print(payload) -- for debugging only
--generates HTML web site
conn:send('HTTP/1.1 200 OK\r\nConnection: keep-alive\r\nCache-Control: private, no-store\r\n\r\n\
<!DOCTYPE HTML>\
<html><head><meta content="text/html;charset=utf-8"><title>ESP8266</title></head>\
<body bgcolor="#ffe4c4"><h2>Hygrometer with<br>DHT22 sensor</h2>\
<h3><font color="green">\
<IMG SRC="http://esp8266.fancon.cz/common/hyg.gif"WIDTH="64"HEIGHT="64"><br>\
<input style="text-align: center"type="text"size=4 name="j"value="'..humi..'"> % of relative humidity<br><br>\
<IMG SRC="http://esp8266.fancon.cz/common/tmp.gif"WIDTH="64"HEIGHT="64"><br>\
<input style="text-align: center"type="text"size=4 name="p"value="'..temp..'"> Temperature grade C<br>\
<input style="text-align: center"type="text"size=4 name="p"value="'..fare..'"> Temperature grade F</font></h3>\
<IMG SRC="http://esp8266.fancon.cz/common/dht22.gif"WIDTH="200"HEIGHT="230"BORDER="2"></body></html>')
end)
end)
