http://www.youtube.com/watch?v=en6QE_2EvQE
Code updated, source is from this forum
-- 18b20 one wire example for NODEMCU
-- NODEMCU TEAM
-- LICENCE: http://opensource.org/licenses/MIT
-- Vowstar <vowstar@nodemcu.com>
-- code from viewtopic.php?f=19&t=752
print(wifi.sta.getip())
wifi.setmode(wifi.STATION)
wifi.sta.config("ap","pass")
pin = 4
ow.setup(pin)
counter=0
lasttemp=-999
function bxor(a,b)
local r = 0
for i = 0, 31 do
if ( a % 2 + b % 2 == 1 ) then
r = r + 2^i
a = a / 2
b = b / 2
return r
function getTemp()
tmr.wdclr()
ow.reset(pin)
ow.skip(pin)
ow.write(pin,0x44,1)
tmr.delay(800000)
ow.reset(pin)
ow.skip(pin)
ow.write(pin,0xBE,1)
data = nil
data = string.char(ow.read(pin))
data = data .. string.char(ow.read(pin))
t = (data:byte(1) + data:byte(2) * 256)
if (t > 32768) then
t = (bxor(t, 0xffff)) + 1
t = (-1) * t
t = t * 625
lasttemp = t
print("Last temp: " .. lasttemp)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
getTemp()
t1 = lasttemp / 10000
t2 = (lasttemp >= 0 and lasttemp % 10000) or (10000 - lasttemp % 10000)
conn:send("<!DOCTYPE html><html><body><p><b>nettemp.pl ds18b20</b><br>Temperature: " .. t1 .. "." .. string.format("%02d", t2) .. "</p></body></html>")
end)
