No wonder I haven't had any luck manipulating it with GPIO1!
The LED works fine with digitalWrite on pin 2!
Are all ESP-12E modules like that?
Explore... Chat... Share...
DannyBoy wrote:I just found out that the onboard LED on my ESP-12E module is connected to GPIO2 pin (thru 470 Ohm internal resistor).
