Decoding 13 results
0x40203e3f: spiffs_page_allocate_data at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_nucleus.c line 941
0x40203e21: spiffs_page_allocate_data at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_nucleus.c line 941
0x40204934: spiffs_object_append at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_nucleus.c line 1122
0x40205ad8: spiffs_cache_page_remove_oldest at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_cache.c line 86
0x4020246d: spiffs_hydro_write at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_hydrogen.c line 980
0x402024e4: spiffs_fflush_cache at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_hydrogen.c line 980
0x40210b51: SPIFFSFileImpl::write(unsigned char const*, unsigned int) at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/spiffs_api.h line 287
0x40202eb6: SPIFFS_close at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs/spiffs_hydrogen.c line 980
0x40210c6c: SPIFFSFileImpl::close() at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/spiffs_api.h line 363
0x4020ea7a: swap at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/FS.cpp line 188
: (inlined by) std::__shared_ptr ::swap(std::__shared_ptr &) at c:\users\usuario\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr_base.h line 936
: (inlined by) std::__shared_ptr ::operator=(std::__shared_ptr &&) at c:\users\usuario\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr_base.h line 860
: (inlined by) std::shared_ptr ::operator=(std::shared_ptr &&) at c:\users\usuario\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits/shared_ptr.h line 291
: (inlined by) fs::File::close() at C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/FS.cpp line 109
0x4020c5b8: ArduinoJson::JsonObject::writeTo(ArduinoJson::Internals::JsonWriter&) const at C:\Users\Usuario\Transporter\TECHNOLOGIES-IoT\Arduino\_Sketches\libraries\ArduinoJson\src/JsonObject.cpp line 44
0x40207d75: operator() at C:\Users\Usuario\Transporter\TECHNOLOGIES-IoT\_TechBubbleProductMasters\Devices\ThermaSenseDS\ThermaSenseDS/ThermaSenseDS.ino line 276
OMG: - can You please provide Your readSpiffs() code? Is there SPIFFS.begin() ? What is the response from SPIFFS.begin() ?
void readSpiffs(){
if (SPIFFS.begin()) {
//SPIFFS.format();
Serial.println(F("Mounted file system!"));
if (SPIFFS.exists("/TechBubbleConfigs.json")) {
File configFile = SPIFFS.open("/TechBubbleConfigs.json", "r");
if (configFile) {
size_t size = configFile.size();
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
if (json.success()) {
if(json["locationID"]!="") {
locationID = json["locationID"].asString();
if(json["zoneID"]!="") {
zoneID = json["zoneID"].asString();
if(json["deviceID"]!="") {
deviceID = json["deviceID"].asString();
if(json["epass"]!="") {
epass = json["epass"].asString();
if(json["esid"]!="") {
esid = json["esid"].asString();
if(json["deviceName"]!="") {
strcpy(deviceName, json["deviceName"]);
if(json["mqttUsername"]!="") {
strcpy(mqttUsername, json["mqttUsername"]);
if(json["mqttPassword"]!="") {
strcpy(mqttPassword, json["mqttPassword"]);
} else {
Serial.println(F("Failed to load json config"));
configFile.close();
} else {
Serial.println(F("failed to mount FS"));
