By Torteski
#24181 Hi all,
I'm having problems with the RCswitch library. The ReceiveDemos work on Arduino 1.6.1 but I can't get them to work with 1.6.4 or 1.6.5. Does anyone have a solution for this?
I've read somewhere on this forum that it has something to do with attachInterrupt being changed.
Any help will be appreciated.
Thank you
By gerardwr
#24187
Torteski wrote:Hi all,
Thank you
In earlier releases this did not work for me either. Today I installed the latest Stable ESP8266-Arduino and now the example ReceiveDemo_simple works.
By Tawhiz20
#24259
gerardwr wrote:In earlier releases this did not work for me either. Today I installed the latest Stable ESP8266-Arduino and now the example ReceiveDemo_simple works.
I am working with 1.6.6 but I can't get it to work... an attached led (to the receiver) lights up (about the same as the led from the remote control) but the program does not signal anything (but a lot of warnings during compilation).
I attached my receiver(5v) with a voltage divider to IO2 and changed the code to "attachinterrupt(2.."
Can you post your code?
THNX
