This reads from eeprom to get SSID and password information. Then trys to connect to it. If it doesn't work, or no SSID is found it boots into a AP mode hosting a configuration webpage.
First pass on this task anyway.
Chris
Explore... Chat... Share...
chriscook8 wrote:https://github.com/chriscook8/esp-arduino-apboot
Chris
CheapB wrote: I wonder if it is possible to use the intended config store instead of the EEPROM store at some point, but this is a great start..
