I am trying to send the data from an ESP 8266 to a raspberry PI server using an example found on the net which works fine, but trying to get it to send multiple values i.e.: temperature humidity and switch values, through one TCP connection without having to disconnect and reconnect for each value string. I would appreciate if somebody with a little more experience than myself can help me out in explaining on how this could be achieved and or provide examples of how this could be done Thank You For Your Time Andy.
#include <Base64.h>
//AP definitions
#define AP_SSID "your AP SSID"
#define AP_PASSWORD "your AP password"
//IoT server definitions
#define IOT_USERNAME "admin"
#define IOT_PASSWORD "test"
#define IOT_IP_ADDRESS "192.168.1.5"
#define IOT_PORT 80
#define IOT_NODE "N8S0"
#define INPUT_PIN 2
#define USER_PWD_LEN 40
char unameenc[USER_PWD_LEN];
bool oldInputState;
pinMode(INPUT_PIN, INPUT);
wifiConnect();
char uname[USER_PWD_LEN];
String str = String(IOT_USERNAME)+":"+String(IOT_PASSWORD);
str.toCharArray(uname, USER_PWD_LEN);
memset(unameenc,0,sizeof(unameenc));
base64_encode(unameenc, uname, strlen(uname));
oldInputState = !digitalRead(INPUT_PIN);
int inputState = digitalRead(INPUT_PIN);;
if (inputState != oldInputState)
sendInputState(inputState);
oldInputState = inputState;
void wifiConnect()
Serial.print("Connecting to AP");
WiFi.begin(AP_SSID, AP_PASSWORD);
delay(1000);
Serial.print(".");
Serial.println("");
void sendInputState(bool inputState)
WiFiClient client;
while(!client.connect(IOT_IP_ADDRESS, IOT_PORT)) {
wifiConnect();
String url = "";
String command = "";
if (inputState)
command = "ControlOn";
command = "ControlOff";
url = "/Api/IoT/Control/Module/Virtual/"+ String(IOT_NODE) + "/"+command; // generate IoT server node URL
Serial.print("POST data to URL: ");
Serial.println(url);
client.print(String("POST ") + url + " HTTP/1.1\r\n" +
"Host: " + String(IOT_IP_ADDRESS) + "\r\n" +
"Connection: close\r\n" +
"Authorization: Basic " + unameenc + " \r\n" +
"Content-Length: 0\r\n" +
"\r\n");
delay(100);
while(client.available()){
Serial.print(line);
Serial.println("Connection closed");
