Even when the esp chip is not connected to the router The access point remains on and i can log into it
If i reboot my router than the esp8266 reconnects
I have also changed my router but the problem persists
* This sketch demonstrates how to set up a simple HTTP-like server.
* The server will set a GPIO pin depending on the request
* http://server_ip/gpio/0 will set the GPIO2 low,
* http://server_ip/gpio/1 will set the GPIO2 high
* server_ip is the IP address of the ESP8266 module, will be
* printed to Serial when the module is connected.
#include <WiFiClient.h>
#include <IPAddress.h>
const char* ssid = "routerssid";
const char* password = "password";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
delay(10);
//WiFi.mode(WIFI_STA);
// prepare GPIO2
pinMode(2, OUTPUT);
digitalWrite(2, 0);
// Connect to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
WiFi.config(IPAddress(192,168,1,252), IPAddress(192,168,1,1), IPAddress(255,255,255,0)); //give fixed ip
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
if (!client) {
return;
Serial.println("new client");
while(!client.available()){
delay(1);
Serial.println(req);
client.flush();
// Match the request
int val;
if (req.indexOf("/gpio/0") != -1)
val = 0;
else if (req.indexOf("/gpio/1") != -1)
val = 1;
else {
Serial.println("invalid request");
client.stop();
return;
// Set GPIO2 according to the request
digitalWrite(2, val);
client.flush();
// Prepare the response
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
s += (val)?"high":"low";
s += "</html>\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
// The client will actually be disconnected
// when the function returns and 'client' object is detroyed
