When I choose the NodeMcu1.0 board (with the 12E) I get this after compiling:
...sketch uses xxx.xxx bytes. Maximum is 1.044.464 Bytes....
Something wrong in the boards-definition?
ESP8266 Arduino add-on
Arduino IDE 1.6.5
Explore... Chat... Share...
martinayotte wrote:Why are you choosing NodeMcu1.0 board if you module is an ESP-12E ?![]()
