Has anyone worked out how to build against the provided Arduino core and libraries, but using an external Makefile?
Explore... Chat... Share...
/Applications/Arduino.app/Contents/MacOS/Arduino --verify --verbose /path/to/ino/file \
--pref build.path=/path/to/build/dir \
--pref sketchbook.path=/path/to/project/dir \
SERIAL_PORT ?= /dev/tty.nodemcu
SERIAL_BAUD ?= 115200
ARDUINO_BIN ?= ~/src/esp/Arduino/build/linux/work/arduino
TARGET = SketchNameHere
arduino:
$(ARDUINO_BIN) -v --upload --board esp8266com:esp8266:nodemcu \
--port $(SERIAL_PORT) --preserve-temp-files \
--pref build.path=build \
--pref target_package=esp8266com \
--pref target_platform=esp8266 \
--pref board=nodemcu \
$(TARGET).ino
