By MeNoGeek
#7643 Hey Mike,
MikeBolton wrote:Python files [...] require you to use the command line interpreter or a DOS window. This is really ‘stone age’
Then why don't you use nodemcu-flasher?
https://github.com/nodemcu/nodemcu-flasher
MikeBolton wrote:You should get a set of massages
Aaaah, okay... ;)
By gwizz
#7645 I like the idea of getting a set of massages too! :)
Perhaps I should try issuing a
Code: Select allAT+HAPPY_END
and wait for something to come forth? :D
Seriously, anyone who sold you on the idea that working with ESP8266 is as easy as arduino should hang their head. It is a significant step up in difficulty, but it is 1/10 of the price and about 10x the functionality. If you are struggling with using the command line or installing stuff from github then you should probably expect to have a steep learning experience!!
But it is good that you documented your experience - it will probably help others - so thank you for that - this is why we are all here after all, to learn and to share our learning. I have attached a copy of your document in rtf format so that it is more accessible for people without Word installed.
(24.36 KiB) Downloaded 309 times
By gtchesla
#7704 Mike,
you are The HERO! Thank you very much for your write-up! I think it should be on the title page... somewhere. It would be absolutely invaluable for the noobs, such myself.
Also, thanks for the Russian software - it is extremely handy. I was using the serial monitor by ElectroDragon before and could not get any response from the module. It turned out that I was not using the "end of the line" character. The monitor you recommend has it as default and I am communicating to ESP! Moreover, it connected to my router.
Arduino is next. :-)
