cendev wrote:i wonder, if this problem is seen only on esp07s with blue antenna... anyone has a white antenna with this problem? I would like to stay away from this manifacturer :/
I can tell you my white antenna model did not have this issue.
Explore... Chat... Share...
rahlquist wrote:cendev wrote:i wonder, if this problem is seen only on esp07s with blue antenna... anyone has a white antenna with this problem? I would like to stay away from this manifacturer :/
