By Beagle
#10753 I've worked with other Wi-Fi adapters and what I've noticed is they generally don't hand out a gateway when they are acting as a DHCP server. This prevents the client device from mistakenly thinking that this device has a link to the internet.
When connected, the client ends up with intermittent connectivity issues because it thinks it can route through 192.168.1.4
Has anyone else experienced this?
By kolban
#24334 Howdy Beagle,
I'm afraid I'm not understanding ... and it is most likely my error. I assume that when an ESP8266 acts as an access point, then stations that connect to it will use the ESP8266 as a gateway to other TCP/IP networks. If the ESP8266 is not connected to any other networks then, obviously, there is no need for a gateway ... unless some other station connects and it itself is available to be a gateway.
Can you elaborate on your comments to help me understand the issue?
By lethe
#24340
kolban wrote:I assume that when an ESP8266 acts as an access point, then stations that connect to it will use the ESP8266 as a gateway to other TCP/IP networks.
The ESP can not act as gateway, since it does not have support for IP routing or masquerading. And a station that connects to an ESP may have more than one network interface, so the ESP may overwrite a previously set default route.
@Beagle: according to the documentation you can prevent the ESP from announcing a route with
Code: Select alluint8 mode = 0;
wifi_softap_set_dhcps_offer_option(OFFER_ROUTER, &mode);
See "2C-ESP8266__SDK__Programming Guide__EN_v1.2.0.pdf" pg. 61
By kolban
#24344 Thanks Lethe, your information is like gold to me.
If one disables the offering of a gateway from an ESP acting as an access point, what then does a station see as a "gateway" when it connects to the ESP?
Neil
