Thanks!
Thanks!
Explore... Chat... Share...
esptool.py --port COM7 write_flash 0x00000 0x00000.bin
esptool.py --port COM7 write_flash 0x40000 0x40000.bin
make: esptool: Command not found
make: *** [firmware/0x00000.bin] Error 127
