By t_i_t_o
#32230 Here is a code for sending mails via SMTP with authentication and SSL support, for example smtp.gmail.com:465. Could be used for sending SMS if operator supports mail2sms service.
Mail subject or body are not mandatory, use NULL if not used.
There is one thing that could be optimized - using the ESP built-in base64_encode() function, but in does not seem reliable so far in terms of memory allocation/freeing.
There is also one possible memory leak - when the SMTP server is down, there is not callback for "connection failed", so there is no way to know the connection did not happen actually and free the allocated memory. But this is true for all TCP connections. A possible solution is to use static memory, but in this case the code is not re-entrant.
Any comments and suggestions are welcome.
Usage:
smtp_send("smtp.gmail.com", 465, "user@gmail.com", "password", "recipient@email.com", "subject", "body");
Enjoy it:
Code: Select all/* ----------------------------------------------------------------------------
 * "THE BEER-WARE LICENSE" (Revision 42):
 * Tito Boro(vski) <t_i_t_t_o@email.com> wrote this file. As long as you retain
 * this notice you can do whatever you want with this stuff. If we meet some day,
 * and you think this stuff is worth it, you can buy me a beer in return.
 * 25.10.2015 Sofia, Bulgaria
#include <esp8266.h>
#define SMTP_MAX_STRING 32
#define SMTP_MAX_BODY 128
static void ICACHE_FLASH_ATTR smtp_dns_found_cb(const char *name, ip_addr_t *ipaddr, void *arg);
typedef enum
   SMTP_STATE_HELO,
   SMTP_STATE_AUTH,
   SMTP_STATE_USER,
   SMTP_STATE_PASS,
   SMTP_STATE_FROM,
   SMTP_STATE_RCPT,
   SMTP_STATE_DATA,
   SMTP_STATE_SUBJ_HEAD,
   SMTP_STATE_SUBJ_BODY,
   SMTP_STATE_SUBJ_FOOT,
   SMTP_STATE_MAIL_BODY,
   SMTP_STATE_MAIL_FOOT,
} SMTP_STATE;
typedef struct
   struct       espconn con; // MUST be first!!!
   esp_tcp    tcp;
   SMTP_STATE    state;
   char       server[SMTP_MAX_STRING];
   char       user[SMTP_MAX_STRING];
   char       pass[SMTP_MAX_STRING];
   char       rcpt[SMTP_MAX_STRING];
   char       subject[SMTP_MAX_STRING];
   char       body[SMTP_MAX_BODY];
} smtp_conn_t;
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
static const uint8_t base64enc_tab[64]= "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
static int base64_encode(size_t in_len, const unsigned char *in, size_t out_len, char *out)
   unsigned ii, io;
   uint32_t v;
   unsigned rem;
   for(io=0,ii=0,v=0,rem=0;ii<in_len;ii++)
      unsigned char ch;
      ch=in[ii];
      v=(v<<8)|ch;
      rem+=8;
      while(rem>=6)
         rem-=6;
         if(io>=out_len) return -1; /* truncation is failure */
         out[io++]=base64enc_tab[(v>>rem)&63];
   if(rem)
      v<<=(6-rem);
      out[io++]=base64enc_tab[v&63];
   while(io&3)
      out[io++]='=';
   if(io>=out_len) return -1; /* no room for null terminator */
   out[io]=0;
   return io;
static void smtp_send_data(smtp_conn_t *smtp_conn, char *data)
   #ifdef PLATFORM_DEBUG
   os_printf(data);
   #endif
    if (smtp_conn->con.proto.tcp->remote_port == 465)
      espconn_secure_send(&smtp_conn->con, (uint8 *)data, strlen(data));
      espconn_send(&smtp_conn->con, (uint8 *)data, strlen(data));
static void ICACHE_FLASH_ATTR smtp_receive_cb(void *arg, char *pdata, unsigned short len)
   smtp_conn_t *smtp_conn = arg;
   char buff[SMTP_MAX_STRING + 16];
   pdata[len] = 0;
   os_printf(pdata);
   #endif
   switch (smtp_conn->state)
   case SMTP_STATE_HELO:
      os_sprintf(buff, "HELO %s\r\n", smtp_conn->server);
      break;
   case SMTP_STATE_AUTH:
      strncpy(buff, "AUTH LOGIN\r\n", sizeof(buff));
      break;
   case SMTP_STATE_USER:
      base64_encode(strlen(smtp_conn->user), (unsigned char *)smtp_conn->user, sizeof(buff), buff);
      strcat(buff, "\r\n");
      break;
   case SMTP_STATE_PASS:
      base64_encode(strlen(smtp_conn->user), (unsigned char *)smtp_conn->pass, sizeof(buff), buff);
      break;
   case SMTP_STATE_FROM:
      os_sprintf(buff, "MAIL FROM:<%s>\r\n", smtp_conn->user);
      break;
   case SMTP_STATE_RCPT:
      os_sprintf(buff, "RCPT TO:<%s>\r\n", smtp_conn->rcpt);
      break;
   case SMTP_STATE_DATA:
      strncpy(buff, "DATA\r\n", sizeof(buff));
      break;
   case SMTP_STATE_SUBJ_HEAD:
      if (*smtp_conn->subject)
         strncpy(buff, "Subject:", sizeof(buff));
         smtp_conn->state = SMTP_STATE_MAIL_FOOT;
         if (*smtp_conn->body)
            smtp_send_data(smtp_conn, smtp_conn->body);
            return;
            strncpy(buff, "\r\n.\r\nQUIT\r\n", sizeof(buff));
      break;
   default:
      return;
   smtp_send_data(smtp_conn, buff);
   smtp_conn->state++;
static void ICACHE_FLASH_ATTR smtp_sent_cb(void *arg)
   case SMTP_STATE_SUBJ_BODY:
      strncpy(buff, smtp_conn->subject, sizeof(buff));
      if (!*smtp_conn->body)
         smtp_conn->state = SMTP_STATE_MAIL_BODY;
      break;
   case SMTP_STATE_SUBJ_FOOT:
      strncpy(buff, "\r\n", sizeof(buff));
      break;
   case SMTP_STATE_MAIL_BODY:
      strncpy(buff, smtp_conn->body, sizeof(buff));
      break;
   case SMTP_STATE_MAIL_FOOT:
      break;
   default:
      return;
   smtp_conn->state++;
static void ICACHE_FLASH_ATTR smtp_disconnect_cb(void *arg)
   os_free(arg);
   os_printf("SMTP disconnected\r\n");
   #endif
static void ICACHE_FLASH_ATTR smtp_reconnect_cb(void *arg, sint8 err)
   os_printf("SMTP disconnected, reconnecting\r\n");
   #endif
   smtp_dns_found_cb(smtp_conn->server, (ip_addr_t *)&smtp_conn->con.proto.tcp->remote_ip, smtp_conn);
static void ICACHE_FLASH_ATTR smtp_connect_cb(void *arg)
   os_printf("SMTP connected\r\n");
   #endif
   espconn_regist_recvcb(arg, smtp_receive_cb);
   espconn_regist_sentcb(arg, smtp_sent_cb);
   espconn_regist_reconcb(arg, smtp_reconnect_cb);
   espconn_regist_disconcb(arg, smtp_disconnect_cb);
   if(ipaddr == NULL)
      os_printf("SMTP DNS lookup failed\r\n");
      #endif
      smtp_disconnect_cb(smtp_conn);
      return;
   os_memcpy(smtp_conn->con.proto.tcp->remote_ip, &ipaddr->addr, 4);
   espconn_regist_connectcb(&smtp_conn->con, smtp_connect_cb);
      espconn_secure_ca_disable(3);
      espconn_secure_set_size(3, 8 * 1024);
      espconn_secure_connect(&smtp_conn->con);
      espconn_connect(&smtp_conn->con);
   os_printf("SMTP connecting to " IPSTR ":%d\r\n",
         IP2STR(smtp_conn->con.proto.tcp->remote_ip),
         smtp_conn->con.proto.tcp->remote_port);
   #endif
void ICACHE_FLASH_ATTR smtp_send(char *server, int server_port, char *user, char *pass, char *rcpt, char *subject, char *body)
   smtp_conn_t *smtp_conn = (smtp_conn_t *)os_zalloc(sizeof(smtp_conn_t));
   if (smtp_conn == NULL)
      os_printf("SMTP mem alloc failed\r\n");
      #endif
      return;
   strncpy(smtp_conn->server, server, sizeof(smtp_conn->server));
   strncpy(smtp_conn->user, user, sizeof(smtp_conn->user));
   strncpy(smtp_conn->pass, pass, sizeof(smtp_conn->pass));
   strncpy(smtp_conn->rcpt, rcpt, sizeof(smtp_conn->rcpt));
   strncpy(smtp_conn->subject, subject? subject: "", sizeof(smtp_conn->subject));
   strncpy(smtp_conn->body, body? body: "", sizeof(smtp_conn->body));
   smtp_conn->con.type = ESPCONN_TCP;
   smtp_conn->con.state = ESPCONN_NONE;
   smtp_conn->con.proto.tcp = &smtp_conn->tcp;
   smtp_conn->con.proto.tcp->local_port = espconn_port();
   smtp_conn->con.proto.tcp->remote_port = server_port;
   ip_addr_t ip_addr;
    switch (espconn_gethostbyname(&smtp_conn->con, server, &ip_addr, smtp_dns_found_cb))
   case ESPCONN_INPROGRESS:
      os_printf("SMTP DNS lookup for %s\r\n", server);
      #endif
      break;
   case ESPCONN_OK:
      smtp_dns_found_cb(server, &ip_addr, smtp_conn);
      break;
   case ESPCONN_ARG:
      os_printf("SMTP DNS argument error %s\n", server);
      #endif
      break;
   default:
      os_printf("SMTP DNS lookup error\r\n");
      #endif
      break;
By t_i_t_o
#33150 Here is an updated version using the built-in base64 encode and healed memory leak. Also put the SDK headers instead of the esp-httpd header in case one want to use it as a stand-alone module.
#include <ip_addr.h>
#include <espconn.h>
#include <mem.h>
#include <osapi.h>
/* Built-in ROM functions */
extern void mem_init(void *);
extern void mem_free(void *);
extern void * base64_encode(const unsigned char *in, size_t len);
void *pvPortZalloc(size_t, const char *file, int line);
void vPortFree(void *ptr, const char *file, int line);
char *ets_strcpy(char *dest, const char *src   );
void *ets_memcpy(void *dest, const void *src, size_t n);
int ets_sprintf(char *str, const char *format, ...)  __attribute__ ((format (printf, 2, 3)));
int os_printf_plus(const char *format, ...)  __attribute__ ((format (printf, 1, 2)));
#define SMTP_MAX_RETRIES    5
#define SMTP_MAX_BODY       64
typedef enum
   SMTP_STATE_HELO,
   SMTP_STATE_AUTH,
   SMTP_STATE_USER,
   SMTP_STATE_PASS,
   SMTP_STATE_FROM,
   SMTP_STATE_RCPT,
   SMTP_STATE_DATA,
} SMTP_STATE;
typedef struct
   esp_tcp       tcp;
   int            retries;
   SMTP_STATE       state;
} smtp_conn_t;
static void base64encode(size_t in_len, const unsigned char *in, size_t out_len, char *out)
   void *pp, *mm = os_zalloc(0x1000 + 32);
   mem_init(mm);
   pp = base64_encode(in, in_len);
   os_strcpy(out, pp);
   os_strcpy(os_strchr(out, '\n'), "\r\n");
   os_free(mm);
   os_printf(data);
   #endif
   pdata[len] = 0;
   os_printf(pdata);
   #endif
      break;
      break;
      base64encode(strlen(smtp_conn->user), (unsigned char *)smtp_conn->user, sizeof(buff), buff);
      break;
      base64encode(strlen(smtp_conn->user), (unsigned char *)smtp_conn->pass, sizeof(buff), buff);
      break;
      break;
      break;
      break;
            return;
      break;
   default:
      return;
   smtp_conn->state++;
      break;
      break;
      break;
      break;
   default:
      return;
   smtp_conn->state++;
   os_free(arg);
   #endif
   os_printf("SMTP disconnected (err %d), ", err);
   if (++smtp_conn->retries > SMTP_MAX_RETRIES)
      os_printf("giving up!\r\n");
      #endif
      os_free(arg);
      os_printf("retrying...\r\n");
      #endif
   #endif
   if(ipaddr == NULL)
      #endif
      return;
   #endif
void ICACHE_FLASH_ATTR smtp_send(const char *server, const int server_port,
               const char *user, const char *pass,
               const char *rcpt, const char *subject, const char *body)
      #endif
      return;
   ip_addr_t ip_addr;
      #endif
      break;
   case ESPCONN_OK:
      break;
   case ESPCONN_ARG:
      #endif
      break;
   default:
      #endif
      break;
