Arduino specifications state that 3.3V out can only deliver 50mA, lower than ESP module needs at peaks. I am wondering if it is possible to power ESP from the 5V on the arduino, using a LM317T regulator.
I plan to use it like in this schematic:
Explore... Chat... Share...
