Esp8266 sms twilio example not compiling
PostPosted: Mon Feb 20, 2023 2:36 pm
by Gabriel Vanlian
Hello:
I created an twilio account to send sms with ESP8266. I got this example from the web, but I didn't compile:
Code: Select all/*
 * Twilio SMS and MMS on ESP8266 Example.
#include <WiFiClientSecure.h>
#include <ESP8266WebServer.h>
#include "twilio.hpp"
// Use software serial for debugging?
#define USE_SOFTWARE_SERIAL 0
// Print debug messages over serial?
#define USE_SERIAL 1
// Your network SSID and password
const char* ssid = "Morosh";
const char* password = "94034690";
// Find the api.twilio.com SHA1 fingerprint, this one was valid as
// of July 2020. This will change, please see
// https://www.twilio.com/docs/sms/tutorials/how-to-send-sms-messages-esp8266-cpp
// to see how to update the fingerprint.
const char fingerprint[] = "BC B0 1A 32 80 5D E6 E4 A2 29 66 2B 08 C8 E0 4C 45 29 3F D0";
// Twilio account specific details, from https://twilio.com/console
// Please see the article:
// https://www.twilio.com/docs/guides/receive-and-reply-sms-and-mms-messages-esp8266-c-and-ngrok
// If this device is deployed in the field you should only deploy a revocable
// key. This code is only suitable for prototyping or if you retain physical
// control of the installation.
const char* account_sid = "1234";
const char* auth_token = "1234";
// Details for the SMS we'll send with Twilio.  Should be a number you own
// (check the console, link above).
String to_number    = "+1234";
String from_number = "+1234";
String message_body    = "Hello world";
// The 'authorized number' to text the ESP8266 for our example
String master_number    = "+1234";
// Optional - a url to an image.  See 'MediaUrl' here:
// https://www.twilio.com/docs/api/rest/sending-messages
String media_url = "";
// Global twilio objects
Twilio *twilio;
ESP8266WebServer twilio_server(8000);
//  Optional software serial debugging
#if USE_SOFTWARE_SERIAL == 1
#include <SoftwareSerial.h>
// You'll need to set pin numbers to match your setup if you
// do use Software Serial
extern SoftwareSerial swSer(14, 4, false, 256);
#else
#define swSer Serial
#endif
 * Callback function when we hit the /message route with a webhook.
 * Use the global 'twilio_server' object to respond.
 void handle_message() {
        #if USE_SERIAL == 1
        swSer.println("Incoming connection!  Printing body:");
        #endif
        bool authorized = false;
        char command = '\0';
        // Parse Twilio's request to the ESP
        for (int i = 0; i < twilio_server.args(); ++i) {
                #if USE_SERIAL == 1
                swSer.print(twilio_server.argName(i));
                swSer.print(": ");
                swSer.println(twilio_server.arg(i));
                #endif
                if (twilio_server.argName(i) == "From" and
                    twilio_server.arg(i) == master_number) {
                    authorized = true;
                } else if (twilio_server.argName(i) == "Body") {
                        if (twilio_server.arg(i) == "?" or
                            twilio_server.arg(i) == "0" or
                            twilio_server.arg(i) == "1") {
                                command = twilio_server.arg(i)[0];
        } // end for loop parsing Twilio's request
        // Logic to handle the incoming SMS
        // (Some board are active low so the light will have inverse logic)
        String response = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>";
        if (command != '\0') {
                if (authorized) {
                        switch (command) {
                        case '0':
                                digitalWrite(LED_BUILTIN, LOW);
                                response += "<Response><Message>"
                                "Turning light off!"
                                "</Message></Response>";
                                break;
                        case '1':
                                digitalWrite(LED_BUILTIN, HIGH);
                                "Turning light on!"
                                break;
                        case '?':
                        default:
                                "0 - Light off, 1 - Light On, "
                                "? - Help\n"
                                "The light is currently: ";
                                response += digitalRead(LED_BUILTIN);
                                response += "</Message></Response>";
                                break;
                } else {
                        "Unauthorized!"
        } else {
                "Look: a SMS response from an ESP8266!"
        twilio_server.send(200, "application/xml", response);
 * Setup function for ESP8266 Twilio Example.
 * Here we connect to a friendly wireless network, set the time, instantiate
 * our twilio object, optionally set up software serial, then send a SMS
 * or MMS message.
        WiFi.begin(ssid, password);
        twilio = new Twilio(account_sid, auth_token, fingerprint);
        #if USE_SERIAL == 1
        swSer.begin(115200);
                delay(1000);
                swSer.print(".");
        swSer.println("");
        swSer.println("Connected to WiFi, IP address: ");
        swSer.println(WiFi.localIP());
        #else
        while (WiFi.status() != WL_CONNECTED) delay(1000);
        #endif
        // Response will be filled with connection info and Twilio API responses
        // from this initial SMS send.
        String response;
        bool success = twilio->send_message(
                to_number,
                from_number,
                message_body,
                response,
                media_url
        // Set up a route to /message which will be the webhook url
        twilio_server.on("/message", handle_message);
        twilio_server.begin();
        // Use LED_BUILTIN to find the LED pin and set the GPIO to output
        pinMode(LED_BUILTIN, OUTPUT);
        #if USE_SERIAL == 1
        swSer.println(response);
        #endif
 *  In our main loop, we listen for connections from Twilio in handleClient().
        twilio_server.handleClient();
I got this error:
https://1drv.ms/t/s!AsZvRpiLVtm4g4sQLF5xnN0RwfjxZA?e=oaP32t
Any help is appreciated
Re: Esp8266 sms twilio example not compiling
PostPosted: Wed Feb 22, 2023 11:33 am
by AcmeUK
Here is a different example to try Send an SMS Using an ESP8266
PostPosted: Thu Feb 23, 2023 2:25 pm
by Gabriel Vanlian
Thanks for reply!
Already tried it without success, different errors:
https://1drv.ms/t/s!AsZvRpiLVtm4g4sYHEDeQUq_EQNyZw?e=pPPigP
PostPosted: Fri Feb 24, 2023 5:24 am
by QuickFix
It looks more like your Arduino IDE installation is messed up; I had similar errors (when I started with Arduino) years ago, which were solved instantly after reinstalling the entire IDE and ESP core as per the documentation. :idea:
