I'm new to ESP8266 environment, but I've some experience on Arduino programming. I've a ESP8266 dev board from ebay, http://www.ebay.com.sg/itm/201345364308. I've successfully controlled all LEDs of the board via IOT Manager app from my galaxy note 3. I'm really happy with it
But I want to try the board with Arduino IDE from https://github.com/esp8266/Arduino. I set up the connection according to the website and tried to write a simple blink code as follow:
const int pinLed = 16;
// the setup function runs once when you press reset or power the board
void setup()
// initialize digital pin as an output.
pinMode(pinLed, OUTPUT);
// the loop function runs over and over again forever
void loop()
digitalWrite(pinLed, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(pinLed, LOW); // turn the LED off by making the voltage LOW
After uploading the sketch, the led is blinking, great!. But I've found the strange message on the serial monitor below:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 28688, room 16
tail 0
chksum 0x45
load 0x3ffe8000, len 1316, room 8
tail 12
chksum 0xb5
ho 0 tail 12 room 4
load 0x3ffe8530, len 1536, room 12
tail 4
chksum 0xbb
csum 0xbb
Where do they come from? I haven't enable the Serial.begin() function.
Any advise or guidance would be greatly appreciated..!!!
pak
