I've got linker errors that happen for some pieces of c++ code, but not for others. Not sure what exactly is triggering them.
While I'm trying to figure out the minimal example to reproduce those, could you please take a look at the errors?
/var/folders/15/ybtbgzpj7636vv4wp92l2c700000gn/T/build859463475789359941.tmp/core.a(HardwareSerial.cpp.o):(.rodata._ZTI6Stream[typeinfo for Stream]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/var/folders/15/ybtbgzpj7636vv4wp92l2c700000gn/T/build859463475789359941.tmp/core.a(HardwareSerial.cpp.o):(.rodata._ZTI14HardwareSerial[typeinfo for HardwareSerial]+0x0): undefined reference to `vtable for __cxxabiv1::__si_class_type_info'
/var/folders/15/ybtbgzpj7636vv4wp92l2c700000gn/T/build859463475789359941.tmp/core.a(Print.cpp.o):(.rodata._ZTI5Print[typeinfo for Print]+0x0): undefined reference to `vtable for __cxxabiv1::__class_type_info'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-abort.o):(.literal+0x0): undefined reference to `_exit'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-abort.o): In function `abort':
abort.c:(.text+0x13): undefined reference to `_exit'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-signal.o):(.literal+0x0): undefined reference to `_getpid_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-signal.o):(.literal+0x4): undefined reference to `_kill_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-signal.o): In function `_raise_r':
signal.c:(.text+0x114): undefined reference to `_getpid_r'
signal.c:(.text+0x122): undefined reference to `_kill_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-mallocr.o):(.literal+0x1c): undefined reference to `_sbrk_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-mallocr.o): In function `malloc_extend_top':
mallocr.c:(.text+0x5e): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x127): undefined reference to `_sbrk_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-freer.o): In function `_malloc_trim_r':
mallocr.c:(.text+0x366): undefined reference to `_sbrk_r'
mallocr.c:(.text+0x38f): undefined reference to `_sbrk_r'
/Users/igrokhotkov/projects/esp8266/arduino/build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib/libc.a(lib_a-freer.o):mallocr.c:(.text+0x3a0): more undefined references to `_sbrk_r' follow
I'm sure all the sbrk, getpid, kill, etc can be replaced with stubs (I'll do that), but what about "undefined reference to vtable for __cxxabiv1::__si_class_type_info"?
