For the brave souls willing to test binutils-2.25, gcc-5.1 and gdb-7.9.1 built by the crosstool-NG-1.21.0 there's a new branch lx106-g++-1.21.0 in the crosstool-NG repository: https://github.com/jcmvbkbc/crosstool-N ... g++-1.21.0
The build steps are the same, just check out another branch:
git clone -b lx106-g++-1.21.0 git://github.com/jcmvbkbc/crosstool-NG.git
cd crosstool-NG
./bootstrap && ./configure --prefix=`pwd` && make && make install
./ct-ng xtensa-lx106-elf
./ct-ng build
I was rather suprised by the following:
int main(char** argv) {
*((char*) 0) = 'x';
compiled with gcc-5.1
xtensa-lx106-elf-gcc -Os --save-temps -c -o null-access2.o null-access2.c
resulted in
.file "null-access2.c"
.global abort
.section .text.startup,"ax",@progbits
.literal_position
.align 4
.global main
.type main, @function
main:
addi sp, sp, -16
s32i.n a0, sp, 12
movi.n a2, 0
memw
s8i a2, a2, 0
call0 abort
.size main, .-main
.ident "GCC: (crosstool-NG 1.21.0) 5.1.0"
My code was replaced with a direct call to abort.
Original code was some deeply nested ((void*)(0)) in some define.
Do I have to provide a dummy abort symbol to avoid the whole family of sbrk, malloc, etc?
Is there some magic switch available?
Do I miss something?
Cal
cal wrote:My code was replaced with a direct call to abort.
Followed by, actually.
cal wrote:Do I have to provide a dummy abort symbol to avoid the whole family of sbrk, malloc, etc?
Interesting. This is clearly an undefined behaviour and that's where gcc would emit trap, and according to the chapter 2.1 here in case it's not implemented a call to abort will be emitted. So yes, we either need a dummy implementation of abort() or we need to implement trap pattern in the gcc. Surprisingly I haven't found any switch to turn it off.
I'll add a patch with the trap pattern implementation.
Thanks for your report!
