By RostakaGmfun
#22762 Hi there!
I am linking with 3rd party SDK (statically). All the user code is being put into .irom0.text section (with ICACHE_FLASH_ATTR define). However, the linker complains about undefined references to all of the symbols from that 3rd-party SDK. I believe this is because SDK code is forced to be in the .text section (am I right?).
So, the question is: how to put SDK code into .irom0.text ?
By jcmvbkbc
#22764
RostakaGmfun wrote:I am linking with 3rd party SDK (statically). All the user code is being put into .irom0.text section (with ICACHE_FLASH_ATTR define). However, the linker complains about undefined references to all of the symbols from that 3rd-party SDK. I believe this is because SDK code is forced to be in the .text section (am I right?).
Hard to tell for sure without looking at the library, code that uses it, link command, linker script and linker error messages, but most probably you're not. The section name where the symbol appears doesn't affect symbol definition.
By RostakaGmfun
#22769
jcmvbkbc wrote:Hard to tell for sure without looking at the library, code that uses it, link command, linker script and linker error messages, but most probably you're not. The section name where the symbol appears doesn't affect symbol definition.
Well, I use esp-rtos-sdk and eagle.app.v6.ld linker script:
Code: Select all/* This linker script generated from xt-genldscripts.tpp for LSP . */
/* Linker Script for ld -N */
MEMORY
  dport0_0_seg :                         org = 0x3FF00000, len = 0x10
  dram0_0_seg :                          org = 0x3FFE8000, len = 0x14000
  iram1_0_seg :                          org = 0x40100000, len = 0x8000
  irom0_0_seg :                          org = 0x40240000, len = 0x3C000
PHDRS
  dport0_0_phdr PT_LOAD;
  dram0_0_phdr PT_LOAD;
  dram0_0_bss_phdr PT_LOAD;
  iram1_0_phdr PT_LOAD;
  irom0_0_phdr PT_LOAD;
/*  Default entry point:  */
ENTRY(call_user_start)
EXTERN(_DebugExceptionVector)
EXTERN(_DoubleExceptionVector)
EXTERN(_KernelExceptionVector)
EXTERN(_NMIExceptionVector)
EXTERN(_UserExceptionVector)
PROVIDE(_memmap_vecbase_reset = 0x40000000);
/* Various memory-map dependent cache attribute settings: */
_memmap_cacheattr_wb_base = 0x00000110;
_memmap_cacheattr_wt_base = 0x00000110;
_memmap_cacheattr_bp_base = 0x00000220;
_memmap_cacheattr_unused_mask = 0xFFFFF00F;
_memmap_cacheattr_wb_trapnull = 0x2222211F;
_memmap_cacheattr_wba_trapnull = 0x2222211F;
_memmap_cacheattr_wbna_trapnull = 0x2222211F;
_memmap_cacheattr_wt_trapnull = 0x2222211F;
_memmap_cacheattr_bp_trapnull = 0x2222222F;
_memmap_cacheattr_wb_strict = 0xFFFFF11F;
_memmap_cacheattr_wt_strict = 0xFFFFF11F;
_memmap_cacheattr_bp_strict = 0xFFFFF22F;
_memmap_cacheattr_wb_allvalid = 0x22222112;
_memmap_cacheattr_wt_allvalid = 0x22222112;
_memmap_cacheattr_bp_allvalid = 0x22222222;
PROVIDE(_memmap_cacheattr_reset = _memmap_cacheattr_wb_trapnull);
SECTIONS
  .dport0.rodata : ALIGN(4)
    _dport0_rodata_start = ABSOLUTE(.);
    *(.dport0.rodata)
    *(.dport.rodata)
    _dport0_rodata_end = ABSOLUTE(.);
  } >dport0_0_seg :dport0_0_phdr
  .dport0.literal : ALIGN(4)
    _dport0_literal_start = ABSOLUTE(.);
    *(.dport0.literal)
    *(.dport.literal)
    _dport0_literal_end = ABSOLUTE(.);
  .dport0.data : ALIGN(4)
    _dport0_data_start = ABSOLUTE(.);
    *(.dport0.data)
    *(.dport.data)
    _dport0_data_end = ABSOLUTE(.);
  .data : ALIGN(4)
    *(.data)
    *(.data.*)
    *(.gnu.linkonce.d.*)
    *(.data1)
    *(.sdata)
    *(.sdata.*)
    *(.gnu.linkonce.s.*)
    *(.sdata2)
    *(.sdata2.*)
    *(.gnu.linkonce.s2.*)
    *(.jcr)
  } >dram0_0_seg :dram0_0_phdr
  .rodata : ALIGN(4)
    *(.rodata)
    *(.rodata.*)
    *(.gnu.linkonce.r.*)
    *(.rodata1)
    __XT_EXCEPTION_TABLE__ = ABSOLUTE(.);
    *(.xt_except_table)
    *(.gcc_except_table)
    *(.gnu.linkonce.e.*)
    *(.gnu.version_r)
    *(.eh_frame)
    /*  C++ constructor and destructor tables, properly ordered:  */
    KEEP (*crtbegin.o(.ctors))
    KEEP (*(EXCLUDE_FILE (*crtend.o) .ctors))
    KEEP (*(SORT(.ctors.*)))
    KEEP (*(.ctors))
    KEEP (*crtbegin.o(.dtors))
    KEEP (*(EXCLUDE_FILE (*crtend.o) .dtors))
    KEEP (*(SORT(.dtors.*)))
    KEEP (*(.dtors))
    /*  C++ exception handlers table:  */
    __XT_EXCEPTION_DESCS__ = ABSOLUTE(.);
    *(.xt_except_desc)
    *(.gnu.linkonce.h.*)
    __XT_EXCEPTION_DESCS_END__ = ABSOLUTE(.);
    *(.xt_except_desc_end)
    *(.dynamic)
    *(.gnu.version_d)
    . = ALIGN(4);      /* this table MUST be 4-byte aligned */
    _bss_table_start = ABSOLUTE(.);
    LONG(_bss_start)
    LONG(_bss_end)
    _bss_table_end = ABSOLUTE(.);
  .UserExceptionVector.literal : AT(LOADADDR(.rodata) + (ADDR(.UserExceptionVector.literal) - ADDR(.rodata))) ALIGN(4)
     _UserExceptionVector_literal_start = ABSOLUTE(.);
     *(.UserExceptionVector.literal)
     _UserExceptionVector_literal_end = ABSOLUTE(.);
  .bss ALIGN(8) (NOLOAD) : ALIGN(4)
    . = ALIGN (8);
    _bss_start = ABSOLUTE(.);
    *(.dynsbss)
    *(.sbss)
    *(.sbss.*)
    *(.gnu.linkonce.sb.*)
    *(.scommon)
    *(.sbss2)
    *(.sbss2.*)
    *(.gnu.linkonce.sb2.*)
    *(.dynbss)
    *(.bss)
    *(.bss.*)
    *(.gnu.linkonce.b.*)
    *(COMMON)
    . = ALIGN (8);
    _bss_end = ABSOLUTE(.);
    _heap_start = ABSOLUTE(.);
/*    _stack_sentry = ALIGN(0x8); */
  } >dram0_0_seg :dram0_0_bss_phdr
/* __stack = 0x3ffc8000; */
  .text : ALIGN(4)
    _stext = .;
    _text_start = ABSOLUTE(.);
    *(.UserEnter.text)
    . = ALIGN(16);
    *(.DebugExceptionVector.text)
    . = ALIGN(16);
    *(.NMIExceptionVector.text)
    . = ALIGN(16);
    *(.KernelExceptionVector.text)
    LONG(0)
    LONG(0)
    LONG(0)
    LONG(0)
    . = ALIGN(16);
    *(.UserExceptionVector.text)
    LONG(0)
    LONG(0)
    LONG(0)
    LONG(0)
    . = ALIGN(16);
    *(.DoubleExceptionVector.text)
    LONG(0)
    LONG(0)
    LONG(0)
    LONG(0)
    . = ALIGN (16);
    *(.entry.text)
    *(.init.literal)
    *(.init)
    *(.literal .text .literal.* .text.* .stub .gnu.warning .gnu.linkonce.literal.* .gnu.linkonce.t.*.literal .gnu.linkonce.t.*)
    *(.fini.literal)
    *(.fini)
    *(.gnu.version)
    _text_end = ABSOLUTE(.);
    _etext = .;
  } >iram1_0_seg :iram1_0_phdr
  .lit4 : ALIGN(4)
    _lit4_start = ABSOLUTE(.);
    *(*.lit4)
    *(.lit4.*)
    *(.gnu.linkonce.lit4.*)
    _lit4_end = ABSOLUTE(.);
  .irom0.text : ALIGN(4)
    _irom0_text_start = ABSOLUTE(.);
    *(.irom0.literal .irom.literal .irom.text.literal .irom0.text .irom.text)
    _irom0_text_end = ABSOLUTE(.);
  } >irom0_0_seg :irom0_0_phdr
/* get ROM code address */
INCLUDE "ld/eagle.rom.addr.v6.ld"
What I actually want to do (figured this out right now) is to move 3rd party library .text segment from .text section to .irom0.text. How can I do this?
By jcmvbkbc
#22772
RostakaGmfun wrote:What I actually want to do (figured this out right now) is to move 3rd party library .text segment from .text section to .irom0.text. How can I do this?
You can do it by changing your ld script like this:
Code: Select all--- eagle.app.v6.ld   2015-07-08 17:40:50.321595028 +0300
+++ eagle.app.v6.ld.mod   2015-07-08 17:42:46.079819303 +0300
@@ -157,6 +157,14 @@
+  .irom0.text : ALIGN(4)
+    _irom0_text_start = ABSOLUTE(.);
+    *(.irom0.literal .irom.literal .irom.text.literal .irom0.text .irom.text)
+    path/to/3rd_party_lib.a:*(.literal .text .literal.* .text.* .stub .gnu.warning .gnu.linkonce.literal.* .gnu.linkonce.t.*.literal .gnu.linkonce.t.*)
+    _irom0_text_end = ABSOLUTE(.);
+  } >irom0_0_seg :irom0_0_phdr
   .text : ALIGN(4)
     _stext = .;
@@ -204,13 +212,6 @@
-  .irom0.text : ALIGN(4)
-    _irom0_text_start = ABSOLUTE(.);
-    *(.irom0.literal .irom.literal .irom.text.literal .irom0.text .irom.text)
-    _irom0_text_end = ABSOLUTE(.);
-  } >irom0_0_seg :irom0_0_phdr
where path/to/3rd_party_lib.a is the exact path used in the link command.
