Apologies in advance if this is the wrong forum for such a question.
I wanted to know whether it was possible to use a Sonoff switch alongside a wall switch as indicated by the ITEAD Indigogo page?
Has anyone done this?
Explore... Chat... Share...
eduperez wrote:What the animation shows is that when the wall switch is at the "off" position, the sonoff device becomes unreachable, and the bulb is always off; if you think about it, that makes perfect sense.
