Calling all GURUs to add an ESP to Costco Plug
PostPosted: Wed Nov 23, 2016 5:02 pm
by markstoehr
Looking for help in integrating an ESP into the circuit in the photos. The device is a wireless (not WIFI) plug. They come in a 3 pack with 1 remote form Costco around $20. On the inside of this device there is a small board with a relay on it. The mains voltage is dropped to 24VDC initially and then to around 5VDC to control the ICs. The relay coil is controlled by a NPN transistor at 24V and 5V. The part I don’t know is the chip U1 and U11. I guess that U1 is another type of transistor as it outputs 5V to the NPN and also on another pin to a status LED. U11 is for the wireless I guess. When you first plug in the device it goes into a sync stage for the remote (blinking LED) and then just works On (LED on) and Off (LED off). Can anyone recognize the 2 U chips? I tried shorting the NPN to 5V but it seems to shutter on and off sometimes and other times just turn on the relay.
Anyone out there a super electronics guru?
I know that I will need 3.3V to power the ESP. Hope to tap off the 5V with another regulator.
Thanks in advance.
Here are the photos they are in a google drive.
https://goo.gl/photos/iaVH1QSd8zYrG7TR6
https://goo.gl/photos/GtPhboDd7N9S3CSv8
https://goo.gl/photos/iUWe7d6W6VojquL47
https://goo.gl/photos/Spg1uzMnhd4Gc4Vh6
Re: Calling all GURUs to add an ESP to Costco Plug
PostPosted: Thu Nov 24, 2016 2:40 am
by villTech
that tranformerless power supply may not be enough to power your esp.
but you seem to have space for 5v/3.3v ac-dc module
PostPosted: Thu Nov 24, 2016 8:23 am
by markstoehr
Yes thank you for that. I was wondering if it had enough to power the ESP. The box has lots of room. May get a cheepo 5V USB wall charger at the dollar store strip it down and add it in. Do you have any idea on the U1 or U11 on the board?
FOR ANYONE THAT MAY FOLLOW THIS AND COPY. THIS IS A CIRCUIT WITH MAIN AC POWER.
IT CAN BE VARY DANGEROUS IF YOU DON'T KNOW WHAT YOU ARE DOING!!!
