This said when I used the sendPanasonic specifying the Panasonic Address and the Hex for the IR it did not work either. So I resorted to use raw data (sendRaw) From the Ir Rec.
The data read dump I got when I switched off the A/C (Off Command) was the following:
Encoding : PANASONIC
Code : C4D3:64800004 (48 bits)
Timing[99]:
+3850, -1450 + 600, -1250 + 600, -1250 + 600, - 500
+ 550, - 550 + 600, - 500 + 600, -1250 + 600, - 500
+ 550, - 550 + 600, -1250 + 600, -1250 + 600, - 500
+ 550, -1300 + 600, - 500 + 550, - 500 + 650, -1250
+ 550, -1300 + 600, - 500 + 600, -1250 + 600, -1250
+ 600, - 500 + 550, - 550 + 600, -1250 + 550, - 550
+ 550, - 550 + 600, -1250 + 550, - 550 + 550, - 550
+ 600, - 500 + 550, - 550 + 550, - 550 + 600, - 500
+ 600, - 500 + 600, - 500 + 600, - 500 + 550, - 550
+ 550, - 550 + 600, - 500 + 600, - 500 + 600, - 500
+ 600, - 500 + 550, - 550 + 600, - 500 + 600, - 500
+ 550, - 550 + 550, - 550 + 600, -1250 + 600, - 500
+ 600, - 500 + 600
unsigned int rawData[99] = {3850,1450, 600,1250, 600,1250, 600,500, 550,550, 600,500, 600,1250, 600,500, 550,550, 600,1250, 600,1250, 600,500, 550,1300, 600,500, 550,500, 650,1250, 550,1300, 600,500, 600,1250, 600,1250, 600,500, 550,550, 600,1250, 550,550, 550,550, 600,1250, 550,550, 550,550, 600,500, 550,550, 550,550, 600,500, 600,500, 600,500, 600,500, 550,550, 550,550, 600,500, 600,500, 600,500, 600,500, 550,550, 600,500, 600,500, 550,550, 550,550, 600,1250, 600,500, 600,500, 600}; // PANASONIC C4D3:64800004
unsigned int addr = 0xC4D3;
unsigned int data = 0x64800004;I am using this code:
#include <IRremoteESP8266.h>
IRsend irsend(0); //an IR led is connected to GPIO pin 0
unsigned int rawData[99] = {3850,1450, 550,1300, 550,1300, 550,550, 550,550, 550,550, 550,1300, 550,550, 550,550, 550,1300, 550,1300, 550,550, 550,1300, 550,550, 550,550, 550,1300, 550,1300, 550,550, 550,1300, 550,1300, 550,550, 550,550, 550,1300, 550,550, 550,550, 550,1300, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 550,550, 600,500, 600,500, 600,500, 600,500, 550,550, 550,1300, 550,550, 550,550, 550}; // PANASONIC C4D3:64800004
void setup()
irsend.begin();
Serial.begin(9600);
t
Serial.println("Raw");
irsend.sendRaw(rawData, 99,38);
delay(2000);
}Can someone pinpoint me in the right direction, would be great if I can put a finger on how to make this work!
Thanks in advance
Chris
