Updated the code. Now it will work good.
I was just finding some good code to write SPIFFS filesystem periodically using Temperature & Humidity Values With Time Date.
I found it nowhere, so i made mine.
Here's a completed project:
Hardware:
DS3231 Module
Esp8266 12E
DHT22
Software side:
Rtclib
Dht lib (Supports DHT11 & DHT22 & More)
The Code starts with Reading File Records and with Forced Offline Mode. Saves Values from DHT22 to SPIFFS Periodocally.
The Code FORMATS the Spiffs on First Use to make a init file (to check its properly formatted).
You can use simple made function to read/write / format the spiffs.
Please feel free to use it.
See it:
Github: http://github.com/ajaybnl
More Source Code on Github
#include <stdio.h>
#include <Arduino.h>
#include <Wire.h>
#include <SPI.h>
#include <FS.h>
#include "DHT.h"
#include "RTClib.h"
RTC_DS3231 rtc;
#define DHTPIN D3
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
long lastReadingTime = 0;
char results[4];
int fail = 0;
int x1 = 0;
unsigned long timer1 = 0;
int offline = 0;
String sdata;
unsigned long timer2 = 0;
int pdate = 0;
Serial.println("init...");
Serial.println("Spiffs Read: ")
//Read all data of file
sdata="";
spiff("data.txt", 1, "");
Serial.println(sdata);
Serial.println("---------");
//DHT init
dht.begin();
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
// if (rtc.lostPower()) {
// Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
// rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(now.dayOfTheWeek());
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
//5 sec timer
if (((millis() - timer2) / 1000) > 5) {
String e = "\r\n";
String date1;
date1 = now.day();
date1 += ":";
date1 += now.month();
date1 += ":";
date1 += now.year();
date1 += e;
String time1;
time1 = now.hour();
time1 += ":";
time1 += now.minute();
//next start write date
if (now.day() != pdate) {
Serial.print("Writing Log: Date ");
Serial.println(date1);
pdate = now.day();
spiff("data.txt", 0, date1);
int h = dht.readHumidity();
int t = dht.readTemperature();
if (isnan(h) || isnan(t) ) {
// Serial.println("Sensor Err");
if (t > 100 || h > 100){t=50;h=50; }// just for test
String d;
d = time1;
d += " T:" ;
d += t;
d += " H:" ;
d += h;
d += "\r\n";
Serial.print("Saving = ");
Serial.print(d);
// Write Data
spiff("data.txt", 0, d);
timer2 = millis();
// Usage: spiff(FILE_NAME,0=WRITE/1=READ,STRING DATA To Write)
//Write String Data: spiff("data.txt", 0, d);
//Read String Data in "sdata" Variable spiff("data.txt", 1);
long spiff(String file, int read, String value = "") {
if (!SPIFFS.begin()) {
Serial.println("Failed to mount file system");
return (0);
FSInfo fs_info;
SPIFFS.info(fs_info);
//Serial.print("Total Bytes: ");
// Serial.println(fs_info.totalBytes);
// Serial.print("Used Bytes: ");
// Serial.println(fs_info.usedBytes);
if ((fs_info.totalBytes - fs_info.usedBytes) < 1000) {
Serial.println("Memory Full");
return (0);
//Init the Spiff FS (check if our INIT file exists or not
File f = SPIFFS.open("init", "r+");
if (!f) {
Serial.println("Formatting Spiff...");
delay(200);
//Format
SPIFFS.format();
//Make a Init File
File f1 = SPIFFS.open("init", "w+");
f1.println("init");
f1.close();
Serial.println("Done");
delay(200);
//If Reading Check file
if (read == 1) {
if (!SPIFFS.exists(file)) {
Serial.println("File not exists");
return (0);
//If Reading Open file R or A
if (read == 1) {
f = SPIFFS.open(file, "r+");
} else {
f = SPIFFS.open(file, "a");
int s = 0;
//if File Exists
if (f) {
s = f.size();
// Serial.printf("File Opened , Size=%d\r\n", s);
//Read
if (read == 1) {
sdata = f.readString();
} else {
//Write data to file
f.println(value);
f.close();
//Return the size of file
return (s);
} else {
Serial.print("Unable to open file ");
Serial.println(file);
