I have read that it needs some delay() and i added some ms but it still not working. Any ideas?
* Arduino home button sketch
* Tzivaras Vasilis
* vtzivaras@gmail.com
#include <WiFiClientSecure.h>
#include <SoftwareSerial.h>
#include <string.h>
#include <stdio.h>
#define BUTTONPIN D3
SoftwareSerial mySerial(D1,D2);
String Data = "";
String password1 = "";
String ssid1 = "";
int button = 0; // 0 isrealeashed, 1 is pressed
char inChar;
int READINGSTATUS = -1;
char str[80] = "This is - www.tutorialspoint.com - website";
const char s[2] = ":";
char *token;
const char* ssid = "";
const char* password = "";
const char* host = "cemup.com";
const int httpsPort = 9002;
// Use web browser to view and copy
// SHA1 fingerprint of the certificate
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
void parseInput() {
int i=0;
int pos = 0;
// Check if full message is received.
for(i=0; i<Data.length(); i++) {
str[pos] = Data[i];
pos++;
delay(5);
token = strtok(str, s);
password1 = token;
while( token != NULL ) {
Serial.println(token );
delay(5);
token = strtok(NULL, s);
ssid1 = token;
break;
//Serial.println("");
//Serial.print("SSID: ");
//Serial.println(ssid1);
//Serial.print("PASSWORD: ");
//Serial.println(password1);
//Serial.println("Serial input was read sucesfully.");
// Setting up Serial communication
mySerial.begin(9600);
// Setting up pins
pinMode(BUTTONPIN, INPUT);
// Blinking red -waiting to connect to a bluetooth device.
// Waiting to reveice data from bluetooth.
delay(35);
Serial.println("Program started...");
Serial.println(micros());
Serial.println(" Android device message:");
while(1) {
delay(20);
if (mySerial.available() > 0) {
char myc = mySerial.read();
Data.concat(myc);
Serial.print(myc);
Serial.print(" ");
delay(20);
if (myc == '>') {
break;
//parseInput();
//mySerial.write("Everything is ok");
//Serial.print("Android said: ");
//Serial.println(Data);
//Serial.println("Connecting with: ");
//char id[ssid1.length()+1];
//ssid1.toCharArray(id, ssid1.length()+1);
//password.toCharArray(password1, );
// Connecting to WIFI hotspot
//Serial.println(id);
ssid = "myssid";
password = "*****";
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Use WiFiClientSecure class to create TLS connection
WiFiClientSecure client;
Serial.println(host);
if (!client.connect(host, httpsPort)) {
return;
if (client.verify(fingerprint, host)) {
Serial.println("certificate matches");
} else {
Serial.println("certificate doesn't match");
String url = "/";
Serial.print("requesting URL: ");
Serial.println(url);
"Host: " + host + "\r\n" +
"User-Agent: BuildFailureDetectorESP8266\r\n" +
"Connection: close\r\n\r\n");
Serial.println("request sent");
while (client.connected()) {
String line = client.readStringUntil('\n');
if (line == "\r") {
Serial.println("headers received");
break;
if (line.startsWith("{\"state\":\"success\"")) {
Serial.println("esp8266/Arduino CI successfull!");
} else {
Serial.println("esp8266/Arduino CI has failed");
Serial.println("reply was:");
Serial.println("==========");
Serial.println(line);
int buttonState = digitalRead(BUTTONPIN);
if( buttonState == 1) {
Serial.println("Button is releashed!");
}else {
Serial.println("Button is pressed!");
//Serial.println("---> Incoming byte!");
Serial.print(myc);
Serial.print(" ");
inChar = mySerial.read();
if(inChar == '<') {
READINGSTATUS = 1;
}else if (inChar == '>') {
READINGSTATUS = 0;
if (READINGSTATUS == 1) {
Data.concat(inChar);
if( READINGSTATUS == 0) {
parseInput();
READINGSTATUS = -1;
delay(50);
