can someone plz. Tell me the sequence of AT command?
Tx
Explore... Chat... Share...
hakha4 wrote:Hi
I wan't to do the same as you. Googling for days without finding any straght answers. Is it possible to connect a server on port x and at the same time listen to port y ?? Did you manage to get this to work? If so please share
Hucke
local SERVER = "192.168.1.25"
local PORT = "2222"
local socket = nil
function senddata()
socket = net.createConnection(net.TCP,0)
socket:on("connection",connected)
socket:connect(PORT,SERVER)
function connected()
local MY_IP_ADDRESS = wifi.sta.getip()
socket:send("MY IP IS "..MY_IP_ADDRESS.."\r\n")
srv=net.createServer(net.TCP)
srv:listen(1111,function(conn)
conn:on("receive", function(client,request)
if(request == "Connect")then
senddata()
end)
end)
