By TheSkeletoN
#12712 Hello!
I made my own telemetry module for RC models, but i have a problem with developing a client software on PC. I tried do it in C# and aslo in Java, but in both case, when I try to get HTTP response, I get error like "Invalid http protocol" or something like this. So I think that something is with configuration of my ESP8266.
In browser it shows up in good way, but in Java or C# it don't work.
Firmware of my ESP is:
AT+GMR
0018000902-AI03
Can you please look at it?
Code: Select all#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <SoftwareSerial.h>
Adafruit_BMP085 sensorBMP180;
SoftwareSerial esp(8,9);
float tempC;
float pressure;
float altitude;
float initAltitude;
float realAltitude;
byte responseCode;
void setup(){
Serial.begin(38400); //turn on serial monitor
esp.begin(38400);
sendCommand("AT+RST\r\n",2000); // reset module
sendCommand("AT+CWMODE=2\r\n",1000); // configure as access point
sendCommand("AT+CIFSR\r\n",1000); // get ip address
sendCommand("AT+CIPMUX=1\r\n",1000); // configure for multiple connections
sendCommand("AT+CIPSERVER=1,80\r\n",1000); // turn on server on port 80
sensorBMP180.begin();   //initialize
initAltitude = sensorBMP180.readAltitude();
tempC = sensorBMP180.readTemperature();
pressure = sensorBMP180.readPressure();
altitude = sensorBMP180.readAltitude();
realAltitude = altitude - initAltitude;
if(esp.available()){
    if(esp.find("+IPD,")){
     delay(2000);
     int connectionId = esp.read()-48;
     String dataToSend = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
     dataToSend += "<telemetry-values>\n<temp>";
     String sVar = String(tempC);
     dataToSend += sVar;
     dataToSend += "</temp>\n";
     dataToSend += "<pressure>";
     sVar = String(pressure/100);
     dataToSend += sVar;
     dataToSend += "</pressure>\n";
     dataToSend+="<altitude>";
     sVar = String(altitude);
     dataToSend += sVar;
     dataToSend += "</altitude>\n";
     dataToSend+="<alt-above-ground>";
     sVar = String(realAltitude);
     dataToSend += sVar;
     dataToSend += "</alt-above-ground>\n</telemetry-values>";
     String cmdCIPSEND = "AT+CIPSEND=";
     cmdCIPSEND += connectionId;
     cmdCIPSEND += ",";
     cmdCIPSEND +=dataToSend.length();
     cmdCIPSEND +="\r\n";
     sendCommand(cmdCIPSEND,2000);
     sendCommand(dataToSend,2000);
     String closeCommand = "AT+CIPCLOSE=";
     closeCommand+=connectionId;
     closeCommand+="\r\n";
     sendCommand(closeCommand,3000);
String sendCommand(String command, const int timeout){
    String response = "";
    esp.print(command);
    long int time = millis();
    while( (time+timeout) > millis()){
      while(esp.available()){
        char c = esp.read();
        response+=c;
   Serial.print(response);
    return response;
By TheSkeletoN
#12739 Ok! So, I get a response from ESP to my client. I had to send a HTTP header with my data. But another problem, I can send only text (and html? I didn't try), but I can't send an XML file. I tried to write to HTTP header Content-type: text/xml, but it didn't work.
EDIT: Nevermind, it's working now! I did silly mistake in my code. ;)
