I have the project to control my roller blinds using a lctech 2 way 5v relay, but I have some trouble by using it. The relays are acting weirdly. Some time they switch on, some time they don't, some time with a delay, some time they switch off before they have to... It is very random...
I am pretty sure of my code because it is working like a charm if I don't use the lctech x2 relay but by connecting directly other relay to the ESP.
Best regards
ps: sorry if it isn't clear, my english is far from perfect
const char* ssid = "###########";
const char* password = "###########";
int max_up = 100;
int max_down = 0;
int time_travel = 20000;
int pos_target = 100;
int pos_actual = 100;
int time_per_percentage_when_go_down = 180;
int time_per_percentage_when_go_up = 193;
byte powerON[] = {0xA0, 0x01, 0x01, 0xA2};
byte powerOFF[] = {0xA0, 0x01, 0x00, 0xA1};
byte updownON[] = {0xA0, 0x02, 0x01, 0xA3};
byte updownOFF[] = {0xA0, 0x02, 0x00, 0xA2};
//Function Prototype
void blind_stop();
void blind_up();
void blind_down();
void blind_move();
WiFiServer server(80);
delay(10);
Serial.begin (115200);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
// Start the server
server.begin();
void blind_up() {
if (pos_actual >= 100){
pos_actual = 100;
blind_stop();
return;
delay(1);
Serial.write (powerON, sizeof(powerON));
delay(2);
Serial.write (updownOFF, sizeof(updownOFF));
delay(time_per_percentage_when_go_up);
if (pos_target == 100)
delay(50);
pos_actual++;
void blind_down() {
if (pos_actual <= 0 && pos_target <= 0){
pos_actual = 0;
blind_stop();
return;
delay(1);
delay(2);
Serial.write (updownON, sizeof(updownON));
delay(time_per_percentage_when_go_down);
pos_actual--;
void blind_stop() {
Serial.write (powerOFF, sizeof(powerOFF));
delay(2);
void blind_move() {
if (pos_actual == 0 && pos_target == 0){
blind_stop();
return;
else if (pos_actual == 100 && pos_target == 100){
blind_stop();
return;
else if (pos_target > pos_actual) {
blind_up();
return;
else if (pos_target < pos_actual) {
blind_down();
return;
else if (pos_target = pos_actual) {
blind_stop();
return;
return;
if (!client) {
blind_move();
return;
while (!client.available()) {
delay(1);
String request = client.readStringUntil('\r');
client.flush();
//Moving request
if (request.indexOf("/blinds/blinds?open=") != -1) {
request.remove(0, 24);
pos_target = request.toInt();
//position request
else if (request.indexOf("/blinds/status") != -1) {
String s = "HTTP/1.1 200 OK\r\nContent-Type: application/json\r\n\r\n{\"position\":\"";
s += pos_actual;
s += "\"}";
client.println(s);
delay(1);
