RGB-LED-Stripe Control (Arduino IDE)
Posted: Mon Jun 08, 2015 8:22 am
Hi guys,
at first sorry for bad english! I hope you can help me
I write a sketch to control my RGB-LED-Stripes via the ESP8266 and 3 N-Channel MOSFETs, it works fine but sometimes without any Error via Serial or hang up all ticker's the server don't answer anymore, i use a LED on port 14 turn on and of every second by a ticker and it works the hole time without a problem!?
My Code:
Serial Output:
I use this SDK-Board:
My Code:
* This sketch demonstrates how to set up a simple HTTP-like server.
* The server will set a GPIO pin depending on the request
* http://server_ip/gpio/0 will set the GPIO2 low,
* http://server_ip/gpio/1 will set the GPIO2 high
* server_ip is the IP address of the ESP8266 module, will be
* printed to Serial when the module is connected.
#include <Ticker.h>
Ticker fader;
Ticker aLife;
const char* ssid = "SSID";
const char* password = "PW";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned int rColor;
unsigned int gColor;
unsigned int bColor;
boolean fadeEnabled = false;
boolean fadeUp = true;
unsigned int fadeState = 0;
double fadeSpeed = 5;
void aLifeLed()
if (digitalRead(14) == true)
digitalWrite(14, LOW);
else
digitalWrite(14, HIGH);
void fadeStart()
fadeState = 0;
fadeEnabled = true;
fader.attach(fadeSpeed/1000, fadeChange);
void fadeStop()
fader.detach();
void fadeChange()
if (fadeState <= 0)
fadeUp = true;
else if (fadeState >= 1023)
fadeUp = false;
if (fadeUp == true)
fadeState++;
else
fadeState--;
analogWrite(15,fadeState);
analogWrite(13,fadeState);
analogWrite(12,fadeState);
delay(10);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(15, OUTPUT);
pinMode(14, OUTPUT);
aLife.attach(1, aLifeLed);
ESP.wdtEnable(WDTO_0MS); // Allready working?
// Connect to AcessPoint
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("Verbinde mit WLAN");
Serial.println("");
Serial.println("");
Serial.print("WiFi \"");
Serial.print(ssid);
Serial.println("\" verbunden");
// Print the IP address
Serial.print("Eigene IP:");
// Start the server
server.begin();
Serial.println("Server wurde gestartet");
if (!client) {
return;
// Wait until the client sends some data
while(!client.available()){
delay(10);
//Serial.println(req);
client.flush();
// Match the request
if (req.indexOf("/rgb?") != -1)
String r = "";
String g = "";
String b = "";
// read colors from request
int rStart = req.indexOf("r=") + 2;
int gStart = req.indexOf("g=") + 2;
int bStart = req.indexOf("b=") + 2;
int rEnd = req.indexOf("&",rStart);
int gEnd = req.indexOf("&",gStart);
int bEnd = req.indexOf(" ",rStart);
r = req.substring(rStart,rEnd);
g = req.substring(gStart,gEnd);
b = req.substring(bStart,bEnd);
// Set LED Color
rColor = r.toInt();
gColor = g.toInt();
bColor = b.toInt();
fadeStop();
analogWrite(15,rColor);
analogWrite(13,gColor);
analogWrite(12,bColor);
else if (req.indexOf("/rgb") != -1)
// Show Site only
else if (req.indexOf("/fade?I") != -1)
fadeStart();
else if (req.indexOf("/fade?O") != -1)
fadeStop();
else {
Serial.println("invalid request");
client.flush(); // Need to flush?
return;
client.flush(); // Need to flush?;
// Prepare the response
String s = "<!DOCTYPE HTML PUBLIC '-//W3C//DTD HTML 4.01 Transitional//EN'><html><head><meta http-equiv='Cache-Control' content='no-store' /><meta name='viewport' content='width=100'/><link rel='icon' type='image/png' href='data:image/gif;base64,R0lGODlhDwAPAKECAAAAzMzM/////wAAACwAAAAADwAPAAACIISPeQHsrZ5ModrLlN48CXF8m2iQ3YmmKqVlRtW4MLwWACH+H09wdGltaXplZCBieSBVbGVhZCBTbWFydFNhdmVyIQAAOw==";
s += "' /><title>RGB ColorControl V0.1(Alpha)</title>";
s += "<script>function changeBackColor () { var red = document.getElementById('r').value; var green = document.getElementById('g').value; var blue = document.getElementById('b').value; red = Math.round(red / 4); green = Math.round(green / 4); blue = Math.round(blue / 4);";
s += " document.body.style.backgroundColor = 'rgb(' + red + ',' + green + ',' + blue + ')';} ";
s += "</script></head><body onload='javascript:changeBackColor()'";
s += "><form action='rgb' method='get'><center>";
s += "<input type='range' id='r' name='r' value='";
s += rColor;
s += "' oninput='javascript:changeBackColor()' onchange='javascript:changeBackColor()' min='0' max='1023'/><br>";
s += "<input type='range' id='g' name='g' value='";
s += gColor;
s += "<input type='range' id='b' name='b' value='";
s += bColor;
s += "' oninput='javascript:changeBackColor()' onchange='javascript:changeBackColor()' min='0' max='1023'/><br><br><button type='submit'>Erleuchten</button></center></form></body></html>";
client.print(s);
delay(1);
Serial Output:
ÈHÌc/hÌøD�•„….ørlVerbinde mit WLAN
WiFi "ChaosWG" verbunden
Eigene IP:192.168.178.37
