This is my code...
id=0 -- Software I2C
io_pin= {[0]=3,[2]=4,[4]=2,[5]=1,[12]=6,[13]=7,[14]=5} -- this maps GPIO numbers to internal IO references
sda=io_pin[2] -- connect to pin GPIO2
scl=io_pin[14] -- connect to pin GPIO14
addr=0x60 -- the I2C address of our device
function initialise()
i2c.setup(id,sda,scl,i2c.SLOW)
write_reg(addr,0x26,0x38)
write_reg(addr,0x13,0x07)
write_reg(addr,0x26,0x39)
print("Waiting for data")
repeat
status = read_reg(addr,0x00)
uart.write(0,".")
until bit.band(status,0x08) == 0x08
print("")
print("Status")
print(status)
Pmsb = read_reg(addr,0x01)
Pcsb = read_reg(addr,0x02)
Plsb = read_reg(addr,0x03)
Tmsb = read_reg(addr,0x04)
Tlsb = read_reg(addr,0x05)
print("Pmsb")
print(Pmsb)
print("Pcsb")
print(Pcsb)
print("Plsb")
print(Plsb)
print("Tmsb")
print(Tmsb)
print("Tlsb")
print(Tlsb)
function read_reg(dev_addr, reg_addr)
i2c.start(id)
i2c.address(id, dev_addr ,i2c.TRANSMITTER)
i2c.write(id,reg_addr)
i2c.stop(id)
i2c.start(id)
i2c.address(id, dev_addr,i2c.RECEIVER)
c=i2c.read(id,1)
i2c.stop(id)
return string.byte(c)
function write_reg(dev_addr, reg_addr, val)
i2c.start(id)
i2c.write(id,val)
i2c.stop(id)
initialise()
And this is the output I get:
Waiting for data
Status
14
Pmsb
14
Pcsb
14
Plsb
14
Tmsb
14
Tlsb
14Having initialised the device, it polls the status register until the device reports that data is available. The status of 14 indicating that there is both pressure and temperature data.
The obvious problem is that every register that I read to retrieve the data returns the same value: 14 (decimal).
I've tried putting some delays in between the write and read steps in read_reg, but it's made no difference.
Can someone point out what I'm doing wrong?
Thanks.
