By chris
#1994 Hi,
I first implemented this tiny project with an Arduino Nano and a 3.3v<->5v 'adapter'.
This way I know a set of working AT+commands to accomplish my goal.
I only need a PWM-port, and the ESP8266 should have that, rendering the Arduino redundant, so I thought I'd just 'port' these AT+commands over.
It compiles with the official SDK in the official VM, and flashing works via esptool.py on the VM's host machine:
Code: Select all# Flashing
./esptool.py --port /dev/tty.SLAB_USBtoUART write_flash 0x00000 bin/eagle.app.v6.flash.bin
./esptool.py --port /dev/tty.SLAB_USBtoUART write_flash 0x40000 bin/eagle.app.v6.irom0text.bin
Code: Select all
// ARDUINO pseudocode without send, receive() and delay(x000). Only AT
// ESP8266 Wifi stuff
AT+CWJAP=\"The Promised LAN\",\"1234567890\"
AT+CIPMUX=1
AT+CIPSTART=4,\"TCP\",\"192.168.178.29\",5000
// do sending and receiving etc pp
AT+CIPCLOSE=4
AT+CWQAP
Code: Select all// ESP8266 AT-example with extensions from at_{ip,wifi,}Cmd.c
  1 #include "ets_sys.h"
  2 #include "driver/uart.h"
  3 #include "osapi.h"
  4 #include "at.h"
  5
  6 #define sleepms(x) os_delay_us(x*1000);
  7
  8 extern uint8_t at_wifiMode;
  9
 10 void user_init(void)
 11 {
 12
 13   uart_init(BIT_RATE_115200, BIT_RATE_115200);
 14   sleepms(3000);
 15   uart0_sendStr("\r\nsetting wifi  mode to stationary\r\n");
 16   sleepms(3000);
 17   at_init();
 18
 19   //{"+CWMODE", 7, at_testCmdCwmode, at_queryCmdCwmode, at_setupCmdCwmode, NULL},
 20   uart0_sendStr("\r\nset cwmode\r\n");
 21   char cwmode[] = "=1\r\n";
 22   at_setupCmdCwmode(0, cwmode);
 23
 24   sleepms(3000);
 25   //{"+CWJAP", 6, NULL, at_queryCmdCwjap, at_setupCmdCwjap, NULL},
 26   uart0_sendStr("\r\njoin ap\r\n");
 27   char cwjap[] = "=\"The Promised LAN\",\"1234567890\"\r\n";
 28   at_setupCmdCwjap(5, cwjap);
 29
 30   sleepms(3000);
 31   //{"+CIPMUX", 7, NULL, at_queryCmdCipmux, at_setupCmdCipmux, NULL},
 32   uart0_sendStr("\r\nset cipmux\r\n");
 33   char cipmux[] = "=1\r\n";
 34   at_setupCmdCipmux(0, cipmux);
 35
 36   sleepms(3000);
 37   //{"+CIPSTART", 9, at_testCmdCipstart, NULL, at_setupCmdCipstart, NULL},
 38   uart0_sendStr("\r\ncipstart to server\r\n");
 39   char cipstart[] = "=4,\"TCP\",\"192.168.178.29\",5000\r\n";
 40   at_setupCmdCipstart(0, cipstart);
 41
 42   sleepms(3000);
 43   //{"+CIPCLOSE", 9, at_testCmdCipclose, NULL, at_setupCmdCipclose, at_exeCmdCipclose},
 44   uart0_sendStr("\r\ncipclose\r\n");
 45   char cipclose[] = "=4\r\n";
 46   at_exeCmdCipclose(0, cipclose);
 47
 48   sleepms(3000);
 49   //{"+CWQAP", 6, at_testCmdCwqap, NULL, NULL, at_exeCmdCwqap},
 50   //at_exeCmdCwqap(0);
 51
 52   sleepms(3000);
 53   //
 54 }
Lets get the the problem! :-) It hangs in line 28.
set cwmode
OK
join ap
The Promised LAN1234567890
# nothing else :-(
I think it freezes somewhere in at_wifiCmd::at_setupCmdCwjap(uint8_t id, char *pPara).
Somewhere after line 380.
350 /**
351 * @brief Setup commad of join to wifi ap.
352 * @param id: commad id number
353 * @param pPara: AT input param
354 * @retval None
355 */
356 void ICACHE_FLASH_ATTR
357 at_setupCmdCwjap(uint8_t id, char *pPara)
358 {
359 char temp[64];
360 struct station_config stationConf;
361
362 int8_t len;
363
364 if (at_wifiMode == SOFTAP_MODE)
365 {
366 at_backError;
367 return;
368 }
369 pPara++;
370 len = at_dataStrCpy(&stationConf.ssid, pPara, 32);
371 uart0_sendStr(stationConf.ssid);
372 if(len != -1)
373 {
374 pPara += (len+3);
375 len = at_dataStrCpy(&stationConf.password, pPara, 64);
376 }
377 uart0_sendStr(stationConf.password); // THIS WAS STILL PRINTED TO UART
378 if(len != -1)
379 {
380 wifi_station_disconnect();
381 mdState = m_wdact;
382 ETS_UART_INTR_DISABLE();
383 wifi_station_set_config(&stationConf);
384 ETS_UART_INTR_ENABLE();
385 wifi_station_connect();
386 // if(1)
387 // {
388 // mdState = m_wact;
389 // }
390 // os_sprintf(temp,"%s:%s,%s\r\n",
391 // at_fun[id].at_cmdName,
392 // stationConf.ssid,
393 // stationConf.password);
394 // uart0_sendStr(temp);
395 os_timer_disarm(&at_japDelayChack);
396 os_timer_setfn(&at_japDelayChack, (os_timer_func_t *)at_japChack, NULL);
397 os_timer_arm(&at_japDelayChack, 3000, 0);
398 specialAtState = FALSE;
399 }
400 else
401 {
402 at_backError;
403 }
404 }
Does anybody know what's going on here to cause the 'AT+CWJAP' to freeze? Setting the mode to 2 gets answered with OK.
edit october 28 22:04:
more details: wifi_station_disconnect() and wifi_station_connect() are blocking calls and nothing goes on. This seems to be a dead end. Is there anywhere a piece of code which explains the whole process a bit better maybe?
By chris
#2066 Hello,
I took inspiration from Sprite_tm. Code now uses callbacks, not that silly direct calling.
Can post it if anybody is interested. (EDIT: attached to this post now)
New problems are all about PWM and servo-control. I wanna use GPIO0 to control a RC servo.
The following code drives the servo to one out of two positions, depending on a variable fetched from a server.
*Starting the ESP8266 with a servo attached prevents it from booting at all.
*If attached later after booting, right after driving to the correct, assigned position, the servo begins drifting annoyingly.
My code base is still the AT-example, so my current suspicion is that something still uses GPIO0 for other work. I cannot find anything though.
It is not the UART1, commenting its initialization did not help the servo drift.
Alternatively a solution against the drift could be pulling the GPIO0 low. Works well with Arduinos. Didnt get it to work with "gpio_output_set (0, GPIO_ID_PIN(0), GPIO_ID_PIN(0), 0);" probably again some other code interfering with the GPIO0's state.
Cheers,
Chris
Code: Select all...
// inspired by the light example in IoT_Demo example
#include "driver/pwm.h"
struct servo_param {
   uint16_t pwm_freq;
   uint8 pwm_duty[PWM_CHANNEL];
   uint8 pad[6-PWM_CHANNEL];
} servo_param;
void user_init(void) {
   servo_param.pwm_freq = 50; // my servo's freq
   servo_param.pwm_duty[0] = 19; // trial and error: 90 degrees servo position
   servo_param.pwm_duty[1] = 0;
   servo_param.pwm_duty[2] = 0;
        pwm_init(servo_param.pwm_freq, servo_param.pwm_duty);
 * called if a tcp client receives anything (over a mux'ed connection)
void my_receiver(char* pdata, unsigned short len) {
   if (len != 1 || pdata == NULL) {
      // something went wrong, expecting either char '0' or char '1'
   char position = *pdata;
   os_printf("Received position %c\n", position);
   if (position == '0') {
      servo_param.pwm_duty[0] = 23; // somewhere to the left-position
   } else if (position == '1') {
      servo_param.pwm_duty[0] = 12; // somewhere to the right-position
   pwm_set_freq(servo_param.pwm_freq);
   pwm_set_duty(servo_param.pwm_duty[0], 0);
   os_printf("Set PWM %d to freq=%d and duty=%d.", 0, servo_param.pwm_freq, servo_param.pwm_duty[0]);
void loop(void) {
EDIT: attached current code.
By mharizanov
#2129
GPIO0 held low (i.e. ground or below 0.7V) will make the module boot in firmware update mode.
I've been experiencing the same with a 3V SSR relay on GPIO2 and not able to find the reason why it won't boot when the relay is connected, works just fine if I connect it after boot.
By chris
#2204 Maybe we should try to solder a thin wire to one of the unused GPIOs of the ESP8266 directly? Has there been work done already?
I just found a thread about the ADC. Gotta do more research about this topic.
