So here's the code. I hope someone may find this useful.
Config
local MISO = 5 --> GPIO14
local CLK = 6 --> GPIO12
local CS = 7 --> GPIO13
local duration = 3000 --> 3 seconds
local i = 0
local result = 0
-- Pin Initialization
gpio.mode(CS, gpio.OUTPUT)
gpio.mode(CLK, gpio.OUTPUT)
gpio.mode(MISO, gpio.INPUT)
gpio.write(CS,gpio.HIGH)
-- Function to read SPI
function readSPI()
gpio.write(CS, gpio.LOW) -->Activate the chip
tmr.delay(1) -->1us Delay
gpio.write(CLK, gpio.HIGH) -->First bit is dummy, ignore it(refer MAX6675 datasheet)
tmr.delay(2)
gpio.write(CLK, gpio.LOW)
tmr.delay(2)
result = 0
for i=15,1,-1
do
result = bit.lshift(result, 1)
result = bit.bor(result ,(bit.band(gpio.read(MISO),0x01)))
tmr.delay(2)
tmr.delay(2)
if(bit.isset(result,2)) then -- refer MAX6675 Datasheet
print("Sensor not connected")
gpio.write(CS, gpio.HIGH)
do return end
print(bit.rshift(result,3)*0.25)
-- Create an interval
tmr.alarm(0, duration, 1, readSPI)
