By podgey
#88201 Does anyone have a link to any documentation or firmware, I am having no luck obtaining any of these after a few hours of looking.
It is the esp 8266-01 module I have connected to my STM32
The current software installed is:
AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:44
Anyt help or advice will be much appreciated!!
By JurajA
#88202 https://www.espressif.com/en/support/download/at
but they didn't built a version of AT 2.1 for esp-01. I have it here
https://github.com/jandrassy/UnoWiFiDev ... T_V2.1.zip
The flashing command of AT2 with esptool is
Code: Select allesptool.py write-flash @download.config
I recommend to change in download.config file flash_mode to dout
https://github.com/espressif/esptool
and the commands reference
https://docs.espressif.com/projects/esp ... index.html
By podgey
#88211 Excellent, thanks so much for the help, I will check those links out when I get home later.
Regarding STM32 using Arduino, I didn't realise that could be done, for now I will stick with the HAL with C that STM provide.
Thanks again!
By podgey
#88401 The updating of the ESP-01 looks tricky to do (not had a go, or bought the parts to update the firmware yet)
Im wondering if I can save time by using a different ESP module which will already be equiped with the MQTT AT firmware such as ESP12E
Could anyone confirm weather this is possible? It might be cheaper and easier to buy one that is ready made
Cheers
