By Salil dhawan
#48160 Hi,
In my program, the program moves from WIFI_STA mode to WIFI_AP and then back to WIFI_STA.
but when I move back from WIFI_AP to WIFI_STA and try to declare the IP on MDNS, it doesnt seem to work. Example code below:
>> ping test.local doesnt work after the setup is completed.
Please help.
Salil
Code: Select all/*
  ESP8266 mDNS responder sample
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
const char* ssid = "Dhawan-2G";
const char* password = "esujgvxp";
// TCP server at port 80 will respond to HTTP requests
WiFiServer server(80);
void setup(void)
  Serial.begin(9600);
  // Connect to WiFi network
  WiFi.softAPdisconnect();
  WiFi.disconnect();
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  // Set up mDNS responder:
  if (!MDNS.begin("test")) {
    Serial.println("Error setting up MDNS responder!");
    while(1) {
      delay(1000);
  Serial.println("mDNS responder started");
    // Add service to MDNS-SD
  MDNS.addService("http", "tcp", 80);
delay(2000);
Serial.print("1");
//--------------------------------Now go to AP mode
 WiFi.disconnect();
  WiFi.softAP("test");
  Serial.println(String("softap started - "));
  WiFi.mode(WIFI_AP);
delay(10000);
Serial.print("2");
  WiFi.disconnect();
  Serial.println("");
    Serial.print(".");
    while(1) {
      delay(1000);
  //MDNS.addService("http", "tcp", 80);
  //MDNS.update();
Serial.print("3");
  server.begin();
  Serial.println("TCP server started");
void loop(void)
  if (!client) {
    return;
  Serial.println("");
  Serial.println("New client");
  // Wait for data from client to become available
  while(client.connected() && !client.available()){
    delay(1);
  // Read the first line of HTTP request
  // First line of HTTP request looks like "GET /path HTTP/1.1"
  // Retrieve the "/path" part by finding the spaces
  int addr_start = req.indexOf(' ');
  int addr_end = req.indexOf(' ', addr_start + 1);
  if (addr_start == -1 || addr_end == -1) {
    Serial.print("Invalid request: ");
    Serial.println(req);
    return;
  req = req.substring(addr_start + 1, addr_end);
  Serial.print("Request: ");
  client.flush();
  String s;
  if (req == "/")
    IPAddress ip = WiFi.localIP();
    String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
    s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 at ";
    s += ipStr;
    s += "</html>\r\n\r\n";
    Serial.println("Sending 200");
    s = "HTTP/1.1 404 Not Found\r\n\r\n";
    Serial.println("Sending 404");
  client.print(s);
  Serial.println("Done with client");
