By Darkwing
#50739 Hi y'all!
Imagine an ESP8622 in a battery-powered portable device. I'm wondering what are my options to get the ESP8622 wake up from a sleep mode, when a specific WiFi SSID is (suddenly) present in the environment. This presence should be the signal for the ESP8622 to start doing things — otherwise it should be asleep.
In other words: Can you think of good ways, to have the ESP8622 in a super low power mode, but like checking for SSID presence as well?
Or: Is there another way, for instance with an additional external component, that listens low-powerly to a specific WiFi beacon, to then trigger the RST on the ESP8622 to wake it up?
Any suggestions and ideas are glady welcome! :P
By Barnabybear
#50921 Hi,
No.
If you give us an idea of what you are wanting to achieve I'm sure someone can help.
By kenn
#50928
Darkwing wrote: I'm wondering what are my options to get the ESP8622 wake up from a sleep mode, when a specific WiFi SSID is (suddenly) present in the environment. This presence should be the signal for the ESP8622 to start doing things — otherwise it should be asleep.
It has to be "awake" to look around and get the available APs, so no, there's no way to "wake" upon detection of a given SSID. Best idea is to simply wake from deep sleep every X minutes, look for the desired SSID, and go back to sleep if it isn't present. Averaged out, that's still pretty low power.
By Darkwing
#50944 The idea is, that I plan to have some sensor units outdoors on several places. These units have the ESP8622. I now want to “collect” the data by occasionally walking around with a laptop’s WiFi and when I'm near such a sensor unit, I want it to wake up (from a battery-saving sleep state), start to connect and transmit its data.
The crucial thing is the “listening for a specific WiFi to connect” during a battery-saving low-current state. I’m aming for µAmps, if it’s possible. In other words: I’m wondering how I could maximize battery life, while also “looking for WiFis”.
Or to put it this way: To save battery life, the ESP8266 is not meant to transmit constantly — but automatically should I be around with my laptop’s WiFi.
So letting the ESP8622 look out for a WiFi every x minutes, when in reality I maybe there once a week, sounds not very efficient.
I wonder: since RFID technology is common nowadays, shouldn’t it be possible to let a 2.4 GHz signal induce a small current, wich then powers circuitry to trigger the RST on the ESP8622? Something like that …
