First of all, thank you very much for your strong support to comunity.
This is my first question. It´s regarding a data sent problem. The problem was I put a ESP8266 server and client. Server found correctly but I tried to send information from ESP to MySql with PHP code but the result was not good.
This is the code:
#include <ESP8266mDNS.h>
#include <string.h>
const char* ssid = "xxxx1";
const char* password = "password";
#define LOCALIP "192.168.1.101" // String for the local server configuration
IPAddress ip_addr(192,168,1,101); //Requested static IP address for the ESP
IPAddress gw(192,168,1,1); // IP address for the Wifi router
IPAddress netmask(255,255,255,0);
WiFiClient client;
const char* host="http://192.168.1.200/";
WiFiServer server(80);
void enviarDatosON() {
String nombre=("LuzComedor");
String estado=("ON");
String data = "nombre=" + nombre + "&ip=" + ip_addr + "&estado=" + estado;
String PostData = ("http://192.168.1.200/xxxxx/xxxxx.php?" + data);
if (client.connect(host, 80)) {
client.println("POST /posts HTTP/1.1");
client.println("Host: http://192.168.1.200/");
client.println("Cache-Control: no-cache");
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(PostData.length());
client.println();
client.println(PostData);
long interval = 2000;
unsigned long currentMillis = millis(), previousMillis = millis();
while(!client.available()){
if( (currentMillis - previousMillis) > interval ){
Serial.println("Timeout");
client.stop();
return;
currentMillis = millis();
while (client.connected())
if ( client.available() )
char str=client.read();
Serial.println(str);
void enviarDatosOFF() {
String estado=("OFF");
String PostData = ("http://192.168.1.200/zaratrusta/zaratrusta.php?" + data);
client.println();
client.stop();
return;
void setup( void) {
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
WiFi.config(ip_addr,gw,netmask);
Serial.println ( "" );
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
Server.begin();
if (!client) {
return;
Serial.println("new client");
delay(1);
Serial.println(req);
client.flush();
int val;
if (req.indexOf("/gpio/0") != -1)
val = 0;
else if (req.indexOf("/gpio/1") != -1)
val = 1;
else {
Serial.println("invalid request");
client.stop();
return;
if (val= 0)
enviarDatosON(); //// use a client to send information to MySQL via PHP
else if (val= 1)
enviarDatosOFF(); //// use a client to send information to MySQL via PHP
else{
// Set GPIO2 according to the request
digitalWrite(2, val);
client.flush();
String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
s += (val)?"high":"low";
s += "</html>\n";
// Send the response to the client
client.print(s);
delay(1);
Serial.println("Client disonnected");
The Output result are:
WiFi connected
Server started
192.168.1.101
new client
GET /gpio/0 HTTP/1.1
Timeout
Client disonnected
new client
Timeout
Client disonnected
new client
The problem is that not save any information in BBDD Mysql.
Do you know any answer? or any way to follow?
Thank you very much.
MaeseLin.
