How to make page index.html send request for NodeMCU 1.0
PostPosted: Tue Jan 03, 2017 1:38 pm
by cyberlacs
I have the following code that works perfectly, if I type in the browser manually http: // http: //192.168.1.49/on or http: // http: //192.168.1.49/off the commands turn on and off the Relay.
I would like to make a page "index.html" that has a link or a button that sends
Http: // IP-esp8266-001 / pin4-on or pin4-off
Http: // IP-esp8266-002 / pin5-on or pin5-off
How could I do this?
I'm waiting
Code below
#include <ESP8266WebServer.h>
const char* ssid = "InvasaoKill+777";
const char* password = "MassaDeTomate183183";
ESP8266WebServer server(80);
int ledPin = 16;
bool ledState = LOW;
//IP do ESP (para voce acessar pelo browser)
IPAddress ip(192, 168, 1, 49);
//IP do roteador da sua rede wifi
IPAddress gateway(192, 168, 1, 1);
//Mascara de rede da sua rede wifi
  pinMode(ledPin, OUTPUT);
  WiFi.config(ip, gateway, subnet);
  WiFi.begin(ssid, password); //Connect to the WiFi network
  while (WiFi.status() != WL_CONNECTED) { //Wait for connection
       Serial.println("Waiting to connect…");
  Serial.print("IP address: ");
  Serial.println(WiFi.localIP()); //Print the local IP
  server.on("/on", turnOn);         //Associate the handler function to the path
  server.on("/off", turnOff);        //Associate the handler function to the path
  server.on("/toggle", toggle);   //Associate the handler function to the path
  server.begin(); //Start the server
  Serial.println("Server listening");
  server.handleClient();
void turnOn()
  ledState = HIGH;
  digitalWrite(ledPin, ledState);
  server.send(200, "text/plain", "LED on");
void turnOff(){
  ledState = LOW;
  server.send(200, "text/plain", "LED off");
void toggle(){
  ledState = !ledState;
  server.send(200, "text/plain", "LED toggled");
Re: How to make page index.html send request for NodeMCU 1.0
PostPosted: Tue Jan 03, 2017 2:20 pm
by edwin
Perhaps I completely underestimate your problem, but usually one does that with <a href="ip nr">ON</a> etc
PostPosted: Tue Jan 03, 2017 2:30 pm
by cyberlacs
I did what you said, but it happens when I click on the link, I'm redirected to the destination, then the links disappear.
Does it have to execute the link and keep on the page, this would have to be in javascript.
I'm waiting.
Code: Select all<html>
   <head>
      <title>ESP8266 LED Control</title>
   </head>
   <body>
      <a href="http://192.168.1.49/on">On</a>
      <a href="http://192.168.1.49/off">Off</a>
   </body>
</html>
PostPosted: Tue Jan 03, 2017 2:59 pm
by cyberlacs
Look now I click on the link I am not redirected but in this case I did not succeed, the command does not trigger the NodeMCU
   <head>
      <script language="JavaScript">
         var myURL='';
         function url1() {
            var myURL = 'http://192.168.1.49/on';
            myMultiLink();
      </script>
   </head>
   <body>
      <a onclick="function url1()" href="javascript:void(0); return false">On</a>
   </body>
</html>
