- Thu Feb 09, 2017 2:51 am#62292
After using the MPRSx8 - Home Automation DevBoard with ESPBasic (driver example here) now it's time to explore also the ESPEasy Firmware capabilities.
- Fri Feb 17, 2017 5:17 am#62692
Part 2 of the series, ESPEasy Firmware Upload tutorial using a simple standard USB-to-Serial Adapter:
Somebody was asking if is really possible to upload firmware with a simple USB to serial adapter, as the ones that are available all over the place. As you can see from the above step-by-step tutorial it is possible and is working very smooth. You are loosing the autoreset and autoupload capabilities of the USBProg board, but as long as you are doing rarely the firmware upload is not so bad. On the other hand, if you want to use it with Arduino IDE or anything else that means frequent upload then I think you will start looking after that functions sooner or later, I think more sooner than later
- Thu Mar 09, 2017 3:13 am#63491Part 3 of the MPRSx8 + ESPEasy Tutorial - This time we will take a deeper look on the ESPEasy Firmware configuration and preparing the MPRSx8 Board for Domoticz integration:
