- Fri Jul 28, 2017 9:20 pm
#68668
I checked around for current specs and it seems to be something that is not typically listed. Of course it would be load and voltage dependent. But the torques is often listed and that too is voltage and load dependent.
I saw only one rating and it listed the stall current to be 360mA. That may be too much for the regulator on the board. It might cause a voltage drop that may cause a reset to the ESP8266.
I am assuming that you would not be running/changing more than one servo at the time. Making sure there is no overlap in operation might allow you to get away with what you planned electrically. Let us know of your results. I am interested in doing something like this as well.
