fetching data from web page using Arduino uno and ESP8266
PostPosted: Tue Apr 03, 2018 7:22 pm
by ali_m
Project goal is to control a relay over web. I made a php page that receives the post data from Arduino then store the values sent into a mysql database (which is the relay status now). Now I need to Get data from a web page which contain the desired relay status, so I used this code:
Code: Select all#include <SoftwareSerial.h>
String ssid ="ABC";
String password="a14102016a";
const byte rxPin = 6;
const byte txPin = 7;
SoftwareSerial ESP8266 (rxPin, txPin);
unsigned long lastTimeMillis = 0;
  ESP8266.begin(115200);
  reset();
  connectWifi();
  delay(2000);
//reset the esp8266 module
void reset() {
ESP8266.println("AT+RST");
delay(1000);
if(ESP8266.find("OK") ) Serial.println("Module Reset");
//connect to your wifi network
void connectWifi() {
String cmd = "AT+CWJAP=\"" +ssid+"\",\"" +password+ "\"";
ESP8266.println(cmd);
delay(4000);
if(ESP8266.find("OK")) {
Serial.println("Connected!");
else {
connectWifi();
Serial.println("Cannot connect to wifi"); }
void printResponse() {
  while (ESP8266.available()) {
    Serial.println(ESP8266.readStringUntil('\n'));
  if (millis() - lastTimeMillis > 30000) {
    lastTimeMillis = millis();
    ESP8266.println("AT+CIPMUX=1");
    delay(1000);
    printResponse();
    ESP8266.println("AT+CIPSTART=4,\"TCP\",\"192.168.1.161\",80");
    delay(1000);
    printResponse();
    String cmd ="GET /ard/sensor.html HTTP/1.1\r\nUser-Agent: curl/7.37.0\r\nHost: %s\r\nAccept: */*\r\n\r\n";
    ESP8266.println("AT+CIPSEND=4," + String(cmd.length()));
    delay(1000);
    delay(1000);
    ESP8266.println("");
  if (ESP8266.available()) {
    Serial.write(ESP8266.read());
But I'm getting strange characters in respond
How can I get a clear response in order to search for a certain value in ?
Thanks in advance
