problema con nodemcu interrupciones y obtener datos firebase
Posted: Tue Jul 09, 2019 1:33 pm
I have problems with a project that detects the zero crossing of a sine wave this is done with the use of interrupts but at the same time you get firebase data, the program works indefinitely and then stops working
I hope someone can help me I have been looking for a solution for days and I can not find
code:
////////////////////////////BRIG//////////////////////////////////////////////////77
uint8_t GPIO_Pin = D1;
int AC_OUT = D5; // Output to Opto Triac
int AC_VALUE = 60; // AC OUT VALUE (0 - 100) *0 = ON BULB; 100 = OFF BULB
// * THESE VALUES ARE UNTESTED, YOU MUST PLAY AROUND WITH THEM) *
int sensorValue = 0;
int value = 0;
int delayTime;
#include <FirebaseArduino.h>
// Set these to run example.
#define FIREBASE_HOST "smarthome-36935.firebaseio.com"
#define FIREBASE_AUTH "mjIg4GMu4aTD7b7fWz12sEMBsIINbkJHMQitun6e"
#define WIFI_SSID "oscar"
#define WIFI_PASSWORD "LALL16281202"
#define ICACHE_RAM_ATTR
//Serial.begin(115200);
////////////////////////////////////////////////////////////////////////////////77
pinMode(GPIO_Pin, INPUT_PULLUP);
pinMode(AC_OUT, OUTPUT); // Set the light control pin as output
// connect to wifi.
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
// Serial.print("connecting");
// Serial.print(".");
// Serial.println();
//Serial.print("connected: ");
//Serial.println(WiFi.localIP());
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
pinMode(D5,OUTPUT);
delay(1000);
attachInterrupt(digitalPinToInterrupt(GPIO_Pin), ICACHE_RAM_ATTR setAC, RISING);
int a= map(Firebase.getFloat("washer/Brightness/brightness"),100,0,10,100);
delayTime = (81*a);
value=delayTime;
void ICACHE_RAM_ATTR setAC() // function to be fired at the zero crossing to dim the light
delayMicroseconds(value); // delay the dim time
digitalWrite(AC_OUT, HIGH); // fire the Triac
delayMicroseconds(55); // pause briefly to ensure the triac turned on
digitalWrite(AC_OUT, LOW); // turn off the Triac gate (triac will not turn off until next zero cross)
code:
int value = 0;
int delayTime;
// connect to wifi.
pinMode(D5,OUTPUT);
delay(1000);
delayTime = (81*a);
value=delayTime;
