#include <ESP8266WebServer.h>
String apiWritekey = "PBD5LAJC4BSV3OKC"; // replace with your THINGSPEAK WRITEAPI key here
const char* ssid = "Dhamaal";// your wifi SSID name
const char* password = "03334204224" ;// wifi pasword
const char* httpserver = "api.thingspeak.com";
ESP8266WebServer server;
WiFiClient client;
// Configuration parameters for Access Point
char * ssid_ap = "ESP_AP";
char * password_ap = "123456789";
IPAddress ip(192,168,11,4); // arbitrary IP address (doesn't conflict w/ local network)
IPAddress gateway(192,168,11,1);
IPAddress subnet(255,255,255,0);
// Set up the server object
// Keep track of the sensor data that's going to be sent by the client
float t1=0.0;
float h1=0.0;
float s1=0.0;
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(ip,gateway,subnet);
WiFi.softAP(ssid_ap,password_ap);
// Configure the server's routes
server.on("/",handleIndex); // use the top root path to report the last sensor value
server.on("/update",handleUpdate); // use this route to update the sensor value
server.begin();
void handleIndex() {
server.send(200,"text/plain",String(t1));
server.send(200,"text/plain",String(h1));
server.send(200,"text/plain",String(s1));// we'll need to refresh the page for getting the latest value
void handleUpdate() {
// The value will be passed as a URL argument
t1 = server.arg("value").toFloat();
h1 = server.arg("value").toFloat();
s1 = server.arg("value").toFloat();
delay(100);
WiFi.begin(ssid, password);
Serial.println(ssid);
Serial.print(".");
Serial.println("");
Serial.print("NodeMcu connected to wifi...");
Serial.println(WiFi.localIP() );
delay(1000);
float t2 = t1;
float h2 = h1;
float s2 = s1;
if (client.connect(httpserver,80))
String tsData = apiWritekey;
tsData+="&field1=";
tsData+=String(t2);
tsData+="&field2=";
tsData+=String(h2);
tsData +="&field3=";
tsData += String(s2);
tsData += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");//command to update
client.print("Host: api.thingspeak.com\n");//host name here thingspeak.com
client.print("Connection: close\n");//closing connection
client.print("X-THINGSPEAKAPIKEY: "+apiWritekey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(tsData.length());
client.print("\n\n"); // the 2 carriage returns indicate closing of Header fields & starting of data
client.print(tsData);
Serial.print("Temp: ");
Serial.print(t2);//printing on serial monitor
Serial.print("Humi: ");
Serial.print(h2);
Serial.print("Soil: ");
Serial.print(s2);
Serial.println("uploaded to Thingspeak server....");//dialogue box
digitalWrite(D4, LOW);
client.stop();//stopping client
Serial.println("Waiting to upload next reading...");
delay(5000);
server.handleClient();
}and the output is
while my client side code is
#include <DHT.h>
// Initialize sensor parameters
// Initialize network parameters
const char* ssid = "ESP_AP";
const char* password = "123456789";
const char* host = "192.168.11.4"; // as specified in server.ino
#define DHTPIN 0 //pin where the dht11 is connected
DHT dht(DHTPIN, DHT11);
// Set up the client objet
WiFiClient client;
// Configure deep sleep in between measurements
const int sleepTimeSeconds = 2;
// Connect to the server
WiFi.begin(ssid,password);
dht.begin();
while(WiFi.status() != WL_CONNECTED) {
Serial.print(".");
Serial.print("IP Address (AP): "); Serial.println(WiFi.localIP());
while (WiFi.status() == WL_CONNECTED) {
int s = analogRead(A0);
float h = dht.readHumidity();
float t = dht.readTemperature();
Serial.print("Temperature: "); Serial.println(t);
Serial.print("Humidity: "); Serial.println(h);
Serial.print("Soil Moisture: "); Serial.println(s);
// Connect to the server and send the data as a URL parameter
if(client.connect(host,80)) {
String url = "/update?value=";
url += String(t);
String url1 = "/update?value=";
url1 += String(h);
String url2 = "/update?value=";
url2 += String(s);
client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" +
"Connection: keep-alive\r\n\r\n"); // minimum set of required URL headers
client.print(String("GET ") + url1 + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" +
client.print(String("GET ") + url2 + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" +
delay(5000);
// Read all the lines of the response and print them to Serial
Serial.println("Response: ");
while(client.available()){
Serial.print(line);
}and the output of this is
Kindly help me to get all correct values at server side. Thanks
