NodeMcu server with multiple sensors connected to client
PostPosted: Sun Sep 08, 2019 8:31 am
by md_jahanzaib
I am trying to connect my nodemcu client with nodemcu server, while my client is connected with two sensors (DHT11 and Soil Moisture) and it is workign perfectly, but on the server side I am unable to get all values, it is only giving me value of one parameter. Server Side Code
#include <ESP8266WebServer.h>
String apiWritekey = "PBD5LAJC4BSV3OKC"; // replace with your THINGSPEAK WRITEAPI key here
const char* ssid = "Dhamaal";// your wifi SSID name
const char* password = "03334204224" ;// wifi pasword
const char* httpserver = "api.thingspeak.com";
ESP8266WebServer server;
WiFiClient client;
// Configuration parameters for Access Point
char * ssid_ap = "ESP_AP";
char * password_ap = "123456789";
IPAddress ip(192,168,11,4); // arbitrary IP address (doesn't conflict w/ local network)
IPAddress gateway(192,168,11,1);
IPAddress subnet(255,255,255,0);
// Set up the server object
// Keep track of the sensor data that's going to be sent by the client
float t1=0.0;
float h1=0.0;
float s1=0.0;
  WiFi.mode(WIFI_AP);
  WiFi.softAPConfig(ip,gateway,subnet);
  WiFi.softAP(ssid_ap,password_ap);
  // Configure the server's routes
  server.on("/",handleIndex); // use the top root path to report the last sensor value
  server.on("/update",handleUpdate); // use this route to update the sensor value
  server.begin();
void handleIndex() {
    server.send(200,"text/plain",String(t1));
    server.send(200,"text/plain",String(h1));
    server.send(200,"text/plain",String(s1));// we'll need to refresh the page for getting the latest value
void handleUpdate() {
  // The value will be passed as a URL argument
 t1 = server.arg("value").toFloat();
  h1 = server.arg("value").toFloat();
  s1 = server.arg("value").toFloat();
  delay(100);
  WiFi.begin(ssid, password);
  Serial.println(ssid);
  Serial.println("");
  Serial.print("NodeMcu connected to wifi...");
  Serial.println(WiFi.localIP() );
  delay(1000);
 float t2 = t1;
 float h2 = h1;
 float s2 = s1;
  if (client.connect(httpserver,80))
         String tsData = apiWritekey;
           tsData+="&field1=";
           tsData+=String(t2);
           tsData+="&field2=";
           tsData+=String(h2);
           tsData +="&field3=";
           tsData += String(s2);
           tsData += "\r\n\r\n";
     client.print("POST /update HTTP/1.1\n");//command to update
     client.print("Host: api.thingspeak.com\n");//host name here thingspeak.com
     client.print("Connection: close\n");//closing connection
     client.print("X-THINGSPEAKAPIKEY: "+apiWritekey+"\n");
     client.print("Content-Type: application/x-www-form-urlencoded\n");
     client.print("Content-Length: ");
     client.print(tsData.length());
     client.print("\n\n");  // the 2 carriage returns indicate closing of Header fields & starting of data
     client.print(tsData);
     Serial.print("Temp: ");
     Serial.print(t2);//printing on serial monitor
     Serial.print("Humi: ");
     Serial.print(h2);
     Serial.print("Soil: ");
     Serial.print(s2);
     Serial.println("uploaded to Thingspeak server....");//dialogue box
  digitalWrite(D4, LOW);
  client.stop();//stopping client
  Serial.println("Waiting to upload next reading...");
  delay(5000);
server.handleClient();
and the output is
while my client side code is
Code: Select all#include <DHT.h>
// Initialize sensor parameters
// Initialize network parameters
const char* ssid = "ESP_AP";
const char* password = "123456789";
const char* host = "192.168.11.4"; // as specified in server.ino
#define DHTPIN 0          //pin where the dht11 is connected
DHT dht(DHTPIN, DHT11);
// Set up the client objet
WiFiClient client;
// Configure deep sleep in between measurements
const int sleepTimeSeconds = 2;
  // Connect to the server
  WiFi.begin(ssid,password);
  dht.begin();
  while(WiFi.status() != WL_CONNECTED) {
  Serial.print("IP Address (AP): "); Serial.println(WiFi.localIP());
   while (WiFi.status() == WL_CONNECTED) {
    int s = analogRead(A0);
    float h = dht.readHumidity();
    float t = dht.readTemperature();
  Serial.print("Temperature: "); Serial.println(t);
  Serial.print("Humidity: "); Serial.println(h);
  Serial.print("Soil Moisture: "); Serial.println(s);
  // Connect to the server and send the data as a URL parameter
  if(client.connect(host,80)) {
    String url = "/update?value=";
    url += String(t);
    String url1 = "/update?value=";
    url1 += String(h);
    String url2 = "/update?value=";
    url2 += String(s);
    client.print(String("GET ") + url + " HTTP/1.1\r\n" + "Host: " + host +  "\r\n" +
                 "Connection: keep-alive\r\n\r\n"); // minimum set of required URL headers
     client.print(String("GET ") + url1 + " HTTP/1.1\r\n" + "Host: " + host +  "\r\n" +
     client.print(String("GET ") + url2 + " HTTP/1.1\r\n" + "Host: " + host +  "\r\n" +
    delay(5000);
    // Read all the lines of the response and print them to Serial
    Serial.println("Response: ");
    while(client.available()){
      Serial.print(line);
and the output of this is
Kindly help me to get all correct values at server side. Thanks
